Question about Samsung Cameras
I have a samsung digital cam i70. If I turn it on and try to shoot a picture it goes off. Is this a battery problem, or something else??
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Camera pictures are saved on camera and not on card
What type and size memory card are you trying to use? The i70 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2014 | Samsung i70 Digital Camera
Canon elph 100 hs can't take pics
The manual is explaining how to work when you can't shoot pictures on page 181 and 182. To much to repeat it here. The manual is still online. But the shooting could be too much for your battery. As a precaution the camera shuts down. Try to recharge the battery. If that does not help, or perhaps you can take one or a few pictures before it shuts down, you know your battery needs to be replaced.
Dec 04, 2013 | Canon PowerShot Cameras
How do i change a screen on a samsung i70 camera
you cant change it yourself and would result in damaging it more. Please get it changed at a service centre
May 01, 2010 | Samsung i70 Digital Camera
My Samsung i70 switches itself off after a couple of seconds
I had the same problem with my camera. It was due to the memory card Apparently not all memory cards are compatible with this camera Try to remove a memory card and turn your camera on without it.
Jan 20, 2010 | Samsung i70 Digital Camera
Charging problems Samsung i70
I have had exactly the same problem. It appears to be to do with a fluctuating power source, believe it or not. I certainly didn't know my power fluctuated! Try charging from different sockets in your house. Mine works in one socket only! It's a single socket, whether that is significant.
Aug 07, 2009 | Samsung i70 Digital Camera
Samsung i70 problem
Yes, we had few situation with different digital cameras and professinal camcorders damaged in I/O port board due to power surge type damage. It is rare but depending on design of circuitry combination with laptop system. Due to the current present on usb port it is important to turn the camera off before unplugging the camera or any electronic devices. Remedy for the damage requires repair by technician. -James
Mar 30, 2009 | Samsung i70 Digital Camera
I get a warning which says *Battery Exhausted*. I've replaced them but still get the warning.. Any idea whats wrong?
earlier i posted solution in similary problem. maybe help you this.
solution is good batteries, Ni-Mh or Lithium, rechargeable only not alkaline. but...problem is how long you watch pictures on lcd display or how much is flash in use. if always by shooting pics used flash that means that you can with best batteries 30, 20 or less pics shooted. and of course, if you connect camera with pc, how long is cam on? just transfer pics on pc and turn the camera off. the best solution is use the card reader for pics transfering.
if is flash off, it's possible to shot 120-150 pics with Ni-Mh. with lithium i don't know, maybe 500 pics. don't use camera lcd for analysing pics it's just there for short preview.
with alkaline batt., very low quality, i shot 30 pics without flash.
i shot also very good pics at night without flash. nikon coolpix L15 can do that but you must have more praxis. alkaline batteries shooting!
after 3 pictures on display is message: warning! the battery is exhausted. what you can do? turn the camera off. wait about 10 minutes. turn the camera on, you can shot 3 or 5 pictures and than turn your camera off again.
you can repeat this few times and you be lucky if you 30 pics captured:)
REMEMBER: all this goes without camera flash!!!
flash and every zooming use more battery power! and that was all magic:).
Mar 22, 2009 | Nikon Coolpix L15 Digital Camera
Low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Cameras Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
