SOURCE: Panasonic nn-k354 microwave
Is it possible that some spray cleaner got into the controls?
I always recommend that users spray cleaner on a soft cloth then wipe the control panel.
I always recommend non-ammonia cleaners since they can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't work, please reply back with your exact model number.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
You may have a bad keypad due to moisture from steam or spray.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
SOURCE: Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
SOURCE: tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you
know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
Whichever option you choose, we have
the service manual for this model and have uploaded it to our
site here to help you.
You will need the free
Acrobat Reader
to view or print it in case you don't have it already.
We're
