Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire professional series dishwasher, PLD2560LCC1
No matter what buttons I push "CL" flashes and the dishwasher won't work
  • vasa129 May 30, 2008
    I am having the same issue. The child lock is not turned on
It is a bad control board. Mine just had the exact same problem and I replaced the board. It is available from the Sears online part store for $112.00. It is not hard to replace if you are somewhat handy.
Posted on Jun 19, 2008
    Genius:
  • 1,073 Answers
The control on the dishwasher is locked look on the console to see the unlock button it will be in you owners manual this is the problem
Posted on May 09, 2008
Why does display flashes "cl"?
Good Afternoon Friend,
I understand the display is flashing "cl" on your Frigidaire dishwasher, model# GLD2450RD. The "cl" code you are seeing is stating to close your dishwasher door. The status indicator lights will also flash to indicate current cycle status. If the door is closed, try pushing it in just to make sure. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire GLD2450RD Built-in Dishwasher
Electrolux PLD2560LCC1 lights flashing
Good Morning Friend,
I understand that you have flashing lights on your Frigidaire dishwasher, model# PLD2560LCC1, and will not start the cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try running the cycle again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dishwashers
Frigidaire Gallery Professional Series GPD8998JC0 ... I can press the buttons to choose my settings but my START/CANCEL button won't work. So I try a 1 hour delay which works but then no water nor the...
Hi Joseph - I understand your dishwasher is displaying a "CL" error code. A "CL" code typically refers to the main door switch. The first easy troubleshooting tip is to flip the circuit breaker to the dishwasher for about 20 minutes and see if that resets it and clears the error. If the circuit breaker trick doesn't work, it could potentially mean that the door is not closed completely. However, it could also mean that the control board is not sensing that the door is properly closed. I would recommend checking the door switches. Look to see if you notice if anything is bent or misshapen. Also, you might try the manufacturer site to see if you can download an owner's manual for future reference. They typically have a large number of owner's manuals for consumer use. If you have tried these troubleshooting tips and still come up with a "CL" code, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
Dec 19, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire dishwasher model FDB2320REC0 when I push the normal wash CL flashes
Hello linda_ross88 - Typically CL indicates that the main control board is not sensing that the door is properly closing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, typically an expert would need to check the door switches, wiring, and test the main control board. Regrettably, this is not a simple DIY job. I would strongly recommend seeking a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 18, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Start button won't work, but delay does
have you accidently turned on a safety feature stopping the machine from starting? or is the door latches closed fully, if opened slightly could be preventing the machine from starting. or maybe its just a faulty start button.
Jul 16, 2012 | Electrolux Frigidaire Professional Series...
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
May 21, 2010 | Frigidaire Dishwashers
Dishwasher Frigidaire Professional Series model PDL4555RFC indicator is flashing Er and other words in red
The dishwasher is junk...poorly designed. Masterboard for electronic buttons keeps shorting out because the dishwasher vents from the top. have this dishwasher and know first hand. had it for about a year and its been fixed several times
Aug 07, 2009 | Frigidaire Professional Series 24 in....
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Electorlux dishwasher flashing CL
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
Oct 24, 2008 | Frigidaire 24 in. FDB2321REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
524 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
