Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
I want the ip to access my router so i can change the default name n put security
    President:
  • 1,851 Answers
You can locate your router's adress with this easy trip:
Hit start - run - cmd. At the new black window that will appear type "ipconfig" without the quotes and hit enter. The system will reply with the the details for IP Adress, Subnet Mask and Default Gateway. The ip adress for Default Getaway is your router's ip adress. This photo may help you:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 01, 2010
I need to lock my router from neighbors using it
For that you need to secure it with WEP password you can set it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security then enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 27, 2011 | NetGear WNR1000 Router
How to put password so the neighborhood couldnt access my dlink router
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank")
Lookup for the options to do the following: -
Next step is to secure it (adding a network security key):
1.On the left-hand side, under Setup, click "Wireless Setup" Click on Setup at the top and then click Launch Wireless Security Setup Wizard. Select your desired encryption method (WEP
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Also, do the following changes: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above steps would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet. Please note down the settings such as SSID Key, User Name/Password and Security as in case you loose this information you cannot recover it back)
You may also download and refer to Page 60 onwards of the PRODUCT MANUAL DIR-625 for further information, if required
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
Hello Need to secure this router but don't know password
hello
if you dont know tghe password you have to reset the password to its factory setting and that way the password gone also, at the back of the router there is small button for reset press that one and it will reset.
thanks
Mar 08, 2011 | Linksys Wireless-G WRT54G Router
How do I change the ssid and make secure
Securing the router:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696
Changing SSID:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
I have WAG200G linksys modem, I need to know how to set a password to my home network so that nobody can access my network
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar. Open an Internet browser. Type "192.168.1.1" (the router's default IP address) in the address bar where you normally type URLs. Press "Enter." Lookup for the options to do the following (Default IP Address, User Name and Password are written at the back of the router): -
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password admin.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.Click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet. You may refer to WAG200 User Guide if required.
Feel free to contract me for further assistance
CreativeTECH
Jan 28, 2011 | Linksys WAG200G Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
214 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
