Question about Kitchen Ranges
ICE BOX STARTED TO RUN WARMER THAN NORMAL,FREEZER OK. NOW FREEZER IS RUNNING WARMER AS WELL AS ICE BOX SIDE
  • 19,396 Answers
Hi.
The most common faults causing this problem are related to the defrost system.
Try performing a complete defrost, leaving the fridge off overnight. If problem disappears and come back after few days or weeks, then you may need to replace defrost termostat, element or fan.
If problem does not come back after defrost, then it was probably due to damper motor blocked by ice.
Other problems that can cause insufficient cooling are compressor problems, refrigerant leaks, and depending on the model, electronic control faults.
Start testing if the problem is the defrost system by leaving the unit disconnected or off for 24 or 48 hours.
As said, if problem was the defrost system, then the problem will disappear after full defrost, to come back in a couple of weeks.
Cross fingers and hope that the problem was fan blades frozen. You can follow the general troubleshooting illustrated here (the article refers to a different fridge, a Whirpool built Kenmore model, things are not too different on your Model):Kenmore side by side...
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Regards.
Posted on Sep 01, 2010
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
What's your problem?ice maker isn't working
Assuming the coils underneath the ice box are clean and the ice box freezer section is running under normal operating conditions so that the ice mold thermostat can close contacts @25F, their are 2 suspects. The ice maker itself and the ice maker's water supply valve. Most of these supply valves have 2 solenoids for ice maker and water through the door. If the water valve is ok then the ice maker is bad.
Sep 27, 2011 | Kenmore Side by Side Refrigerator
Refer is not cooling, but freezer works OK. This happened after a 3 hour power outage.
If the freezer box is good and making ice thats dry, its an airflow issue. The reefer box section is reliant upon the freezer box section for its cold air, it has no evaporator of its own. There are 2 dials or controls one says 1-10 and has an OFF position that will shut off the compressor. The other says COLDER/WARMER and will not shut down anything except the flapper door that regulates the amount of air allowed to migrate into the reefer box from the freezer box. The normal reaction when finding a warm box is to max out both settings! 19 rather than 1 and COLDER rather than WARMER, setting. Which sounds correct, except the COLDER means colder freezer box, not reefer box, thus closing down even further the amount of air available to the reefers box. Sounds crazy and really makes a customer mad to pay $75 for a guy to turn the COLDER to WARMER and be done! Many question its accuracy , yet learn soon when the refers cold again. or they remove the back panel to see for themselves and operate the setting to see the flappers workings.
Nov 01, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
I have Kenmore refregrator model 51272200. Water is leaking inside and forming ice at the bottom of the freezer. The refregrator compartment is warmer than usual. Your help on this is greately appreciated....
CK THE ICE MAKER WATER INLET TUBE IT MAY BE ICED AND CAUSING THE WATER TO RUN DOWN THE BACK / ALSO CK THE DRAIN IN BOTTOM OF FREEZER / A VERY COMMON PROBLEM . THIS WILL ICE THE BOTTOM OF FREEZER FLOOR AND RUN OUT ON FLOOR .. .. MM HOPE THIS HELPED ..
Jul 01, 2010 | Kenmore 53092 / 53094 Side by Side...
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
