Hi, i have an i ball C12.0 face to fac ecam which I bought a year ago but have been using for the past 6 months.I tried plugging in the cam now but eventhough the led lights come on ,the computer isn't detecting the cam.pls help
  • Computers & ... Master
  • 2,727 Answers
Download from the Iball website
Use 'Camera' for the Category and then select your model when the options load
http://www.iball.co.in/Download.aspx
Posted on Sep 01, 2010
2005 Yamaha Enticer 125 dripping oil out of exhaust
Hi, Ryan and the usual suspects are:
1. Engine oil system overfilled.
2. Piston rings worn past service specs.
3. Broken piston rings.
4. Piston pin retaining clip failure.
5. Cracked piston.
6. Broken piston ring lands.
7. Hole in the piston.
8. Valve/guide clearance worn past service specs.
9. Worn out valve seals.
10. Crushed or loose valve seal.
11. Gouges in cylinder walls.
12. Cracked cylinder or head.
13. Blown head gasket.
14. Crankcase breather blocked or hose pinched.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Message Board Motorcycle USA
Oil coming out of exhaust
Yamaha YBR 125 Service Manual
OEM parts for Yamaha
YAMAHA YBR125 Owner Manual
Jul 11, 2017 | Yamaha Motorcycles
Computer not charging
Sounds like you got a bad battery probably need a new one. Click here for tech support
Mar 26, 2013 | HP Pavilion Computers & Internet
1110 SECURITY CODE
hi if you forget the security code try default codes like 0000 or 1234 to reset your mobile .if it didnt help you to reset then visit onlinegsmunlock.com here they provide master reset codes for some nokia and alcatel mobile models.
Jul 15, 2012 | Cell Phones
87, 2.9L, 5spd ranger. I would like to know if u can
The TFI ignition module is mounted to the side of the distributor two 7/32" machine screws hold it on, requires a special tool to remove it. Our fuse box diagrams only go back to 1996 model year.
Feb 02, 2012 | Washing Machines
I have an HP G60-235X that I purchased a little more than a year ago. About 6 months ago, I began to notice less charge life in the battery and a very high temperature from the battery pack. Now, and...
You need a new battery. One or more cells is defective. Obviously it's unsafe to continue using a battery pack if it gets hot enough to cause burns, so remove the pack from the computer. You can continue to use the computer on AC power until you get a replacement battery.
You might try contacting HP to see if there's any kind of warranty accommodation they can make. I've found several mentions in various forums about batteries in similar models going bad and that HP replaced them, but they were all within a year of purchase. Can't hurt to ask, though.
Jul 09, 2011 | HP G60-235DX Notebook
Hi... I bought a new Honda *** April 2010 - last year. For the past 6 months i am facing terrible trouble starting my ***. Self Start s completely down. Only option is to Kick start which also fails a lot...
have you change your spark plug? if no better change. increase idle rpm of your carburetor a little bit so that it will not stop on heavy traffic.
Apr 26, 2011 | 2005 Honda Dio
Shaking when driving. bought new tires in front 18 months ago. bought the car 3 years ago it was already lowered bought back tires six months ago had alighned two months ago started shaking after and tires...
get under the vehicle (use ramps) and check all linkages for movement pull push on the anti roll bar links, pull push on steering rack and pinion and linkages, any excessive movement, jack each wheel at a time, using a bar check the lower wishbone joints for movement, get the bar in the gap between the wishbone and lower part of the shock. and pull down, if any movement in ball joint up and down replace. while wheel on vehicle check for movement in bearing you will feel a tiny amount not much but pull and push on wheel with opposite hands on 12 o'clock and 6 o'clock and do the same at 9 and 3. now with both wheels off the ground but with the tyres still on, have some one holed one wheel and push pull on wheels each side there should be even movement between both wheels, if everything is fine with the the steering linkages and this dose not feel or sound right then this could be the problem also to add if the inside and out side of the tyres are wearing then the tyre pressure is wrong and needs adjusting to the right tyre pressure .
Jul 24, 2017 | 2000 Ford Mustang
I want a driver for I ball C2.0 face to face webcam
http://www.multiupload.com/VYSSJVCPLD
Aug 15, 2009 | Logitech Webcam
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
