Cannot connect to the wireless network. it states its connected but it still does not work
  • 81 Answers
You may have security protocals installed preventing unwanted outsiders from using your network. Connect the laptop via an ethernet cable to your router and log in. You should be able to find the key you need. Enter this into your computer's wireless connection settings (you can get there by right clicking on the wireless connection and choosing properties).
Posted on May 09, 2008
Where is switch on dell latitude e6400 to enable wireless internet access?
hi
go to this link, review
What You Need to Establish a WLAN Connection http://support.dell.com/support/edocs/systems/ins6400/en/om/network.htm#wp1052373
  1. Click the Start button, point to Settings, and then click Control Panel.
  2. Double-click Network Connections.
  3. Right-click the Wireless Network Connection icon, and then click View Available Wireless Networks.
If the Choose a wireless network window states Windows cannot configure this connection, the wireless network card's configuration utility is managing the wireless network card.
If the Choose a wireless network window states Click an item in the list below to connect to a wireless network in range or to get more information, the Windows XP operating system is managing the wireless network card.
Dec 01, 2010 | Dell Latitude E6400 Notebook
Can connect to wireless network with my laptop, but 2nd home PC will not connect, stating that the wireless connection is not connected - yet it also states the hardware is functioning correctly. What do I...
If you know what the spec for your laptop is check the encryption its capable of on a wireless network. If it an older laptop then its probably only 64bit encryption whereas your router is probably 128bit. If this is the case you need to set your router to 64bit encryption for it to work, and then the access key for your 2nd home pc to work
Apr 17, 2010 | Linksys : Wireless-G PCI Adapter with...
Cannot get wireless connection onlaptop .
you can try disconnecting and connecting again from your wireless network. if that doesn't work, try to access the configuration page of your wireless router, try to type in a different password for your wireless network and try connecting again.
Jul 11, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
My wireless assistant works properly for about 25 mins after switching on the laptop, then it state that the LAn is not connected to the internet anymore, although other computers easily access the net...
It's been isolated that the problem is coming from the wireless adapter on your laptop since other pc works fine. Try updating the driver on your wireless adapter and see if that will resolve your intermittent connection.
Jan 12, 2009 | Intel PRO/Wireless 3945ABG Network...
I need to turn my wirless internetnet option on and cant for my IBM thinkpad thanks
mostly the button is found on the left float side of your laptop 'IBM'. with two icons of a computer. please make sure that the button is on the side of the icon that shows a computer with weaves. so that your able to check the wireless access points you have in your range.
Wireless Connection:
Start > Control Panel > network connection>
Show network connections. If there is an X on wireless connection then connection is disabling and if no X then connection is enable.
make sure its enabled.
Right click on wireless network connection and click view available wireless networks.
You should see a list of available wireless networks
Then select the wireless network that you need to work on and click connect.
An icon in the lower right hand corner of your laptop should eventually appear stating that you are connected.
Then this will show you your wireless connection.
Excellent you connect to your wireless network.
Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
G wireless router
You should disable the WAN miniport pppoe. SSID is the wireless network name or the signal's name coming from your wireless router.
After disabling the wan miniport, Right-click on Wireless Network Connection > View Available Wireless Network. If you see several networks listed, highlight your wireless network and click Connect. That should do it.
Sep 28, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection
You need the pass key for the wireless network you're attempting to connect to in order to complete the connection. When you look at the available networks you'll find that the one you're attempting to connect to is "locked".
Aug 17, 2008 | HP Pavilion dv6000z Notebook
CGA5722 - Boxed in "A
can you a little bit describe what other device that you are using. maybe access point. Are you using an access point?, or switch?
Feb 15, 2008 | Computers & Internet
Wireless network connection is established but still getting "Server not found" error in IE
My name is Laxman.,
your two computers working fine with the wireless connection but new laptop not working with it. I am not sure about the operating system of your computer.
If it is Win XP, then follow this instruction.,,
- Go to wireless connection properties and check the "Preferred Networks" , if you have any in ther,. delete it.
Check this link for wireless configuration in XP computer.
http://www.portforward.com/help/wirelessxp.htm
Still if you have any problem, you may try this option :-
- Click start and go to RUN, Type in " services.msc ", you can see the Services window with bunch of services in there. please find " Wireless Zero Configuration ". make sure its enabled. If its enabled, right click on it & go to properties. you can Stop and restart the wireless zero configurations. And check your wireless connection.
Nov 04, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
