Question about Maytag MSD2756G Side by Side Refrigerator
I need a new filter for the fridge and am not sure where to purchase one from for May Tag fridge freezer.
    President:
  • 1,891 Answers
The filter is avalb from most appl dist or lowes a nd home depot . if you do not have stores in your area you can order from sears . parts . mm
Posted on Sep 01, 2010
Model #3074AN the freezer is working but the fresh food section isn't cooling. was purchased new on 4/28/08.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Apr 04, 2011 | Whirlpool Refrigerators
Fridge is freezing in weird spots, the water filter froze, it was time to replace it, so I did and the new one froze as well. Also, are the water filters a one shot deal? I took it out to see if it was...
Make sure the evaporator fan in the freezer is running when the compressor runs and make sure the vent from the freezer to the fridge is open allowing for the air to circulate. There is also a vent at the bottom to allow the air to return to the freezer. Make sure it's open.
You may need to let the filter dry out so it will return to it's original size and shape so you can get it back in.
Jan 20, 2010 | Refrigerators
I have a brand new kenmore elit bottom mount freezer and the fridge part keeps freezing food. I have it set at the recommended settings. I have already replaced this fridge once because of the same issue....
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge thermostat appears to have failed. Freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 20, 2009 | Refrigerators
Freezer door pops open when close fridge
There are a few things you could try. Make sure both the gasket and the area around the opening that the gasket rests on are clean dry and not iced over. Make sure your fridge is level. If those do not work you may need a new gasket. One thing is for sure it is Not normal. You could also try contactging a supervisor at A&E and explain what happened. You may have got a repairman who was having a bad day or just plain lazy! Good Luck!
Jul 21, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Water Filter
Open the fridge site, look up at the top right corner, half way to the back, you'll see the filter laying horizontally against the top of the fridge.
Push a button with the arrow to pull down the cover, you'll see the filter.
Twist the filter counter clockwise to remove it. My filter name is Puriclean II. Yours could be different.
Feb 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Filter status, display help
This is normal. The light is on only when it's time to change the filter. I guess you have already found the filter timer reset procedure in your owner's manual!
Enjoy your new fridge!
Mar 12, 2008 | Refrigerators
No water to door
Did you change any settings resently or move the fridge? Water line could be kinked. Could be a frozen water line. If the ice maker is set on rapid ice, turn it off. You could turn the temp setting down for a day to see if that helps. Do you have any leaks behind or under the fridge? Check the filter again, make sure you pulled the shipping tag off and that it is seated properly. Freezer temp could be set too cold. Make sure the freezer door closes properly and that there isn't anything hendering it.
Jul 07, 2007 | Kenmore 56722 / 56724 / 56726 / 56729
Maytag MSD2756G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
