Question about KitchenAid KHMS145J Microwave Oven
While heating something up it started make noise like it was shorting out, I immediately unplugged the unit. What could this be and would it be repairable
  • KitchenAid Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Most of the time when the microwave is in use and just quits either the Power Diode or the capacitor has failed and blows the fuse inside the cabinet. (Yours is probably NOT blown.)
Diode:
http://www.appliancepartspros.com/part_details.aspx?part_id=4310285
Location Item 19
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260502&diagram_id=94048#d94048
Capacitor: (Location Item 20 above link)
http://www.appliancepartspros.com/part_details.aspx?part_id=4295779
Since you unplugged the unit before the thermal fuse blew you were very wise: (Item 28 of interior diagram)
http://www.appliancepartspros.com/part_details.aspx?part_id=4308182
With the unit unplugged and the chassis cover removed the fuse will be located at the end of the power cord lead in a fuse holder. The fuse is usually a 15A 250V slow-blo fuse. Just replacing the fuse will normally result in the fuse failing yet again.
STOP! Before going any further you must hold a well insulated screwdriver back on the handle and short across the High Voltage Capacitor at least 3 times! Failure to do so could be the start of a very bad day in the form of a horrible shock.
Next you disconnect one side of the cap including the power diode wire. With an analog meter set on R x 1,000 read the Cap terminals watching for a jump. Reverse the meter leads on the terminals and watch for a jump EACH time you reverse the test leads on the CAP terminals.
No jump = bad cap.
Constant resistance across the cap = bad cap
Lastly you check the power diode with the meter on the same settings R X 1,000. One direction will read full continuity (ZERO) and reversing the leads will read infinity. (no reading)
If the diode reads open both ways = failed
If the diode reads (ZERO) both ways = failed
It must read continuity in ONE direction only.
After finding and replacing the failed component then you can change the fuse and test the microwave.
There is a very very remote possibility that a door switch has failed but given that your microwave failed while in use I seriously doubt you have a door switch problem.
As far as finding replacement parts for your microwave nearly every appliance parts store will have what you need if you walk in with the failed part in hand. Most of the time they will walk back and grab the part you need without even digging in the parts books.
These are the most common failures when a unit quits working while in use. Yes I believe your unit is repairble at a very reasonable cost.
Thanks for choosing FixYa.
Kelly
Posted on Sep 01, 2010
Sharp 1200w microwave seems to be tripping lightly (can hear clicking noises)and cause heating to be irregular
Clean the food off the inside top of the microwave Now,Or that noise you are hear will stop along with the microwave. The food gets on the Formica Squire which is how the micro waves heat your food. 1st unplug the Microwave then spray the inside of the unit with something like Fantastic or something strong and use glove so you don't burn you hand,Also if you have a scrub brush use it,And clean all the soap out and raise very well.
May 02, 2012 | Sharp Microwave Ovens
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
Crackling noise, like something is shorting out, came from GE Spacemaker XL1800 JVM1850WF001. I immediately turned it off but I don't know where to start to figure out the problem.
If the interior is dirty or the wave guide dirty or worn out it can cause this. The wave guide is on the interior and looks like a piece of stiff paper. Clean it carefully as it's delicate.
Dec 08, 2010 | GE Microwave Ovens
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
Ge profile wont heat
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.microtechfactoryservice.com/diode.html
(if it\'s not shorted or burned, it\'s
probably okay)
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven
here.
We\'re happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
Jun 04, 2009 | Microwave Ovens
Dacor Microwave - Light/Turntable turn on if we close the door
Sorry but I meant to also ask if it will still heat the food when you microwave with it.
I'll assume it does, but if not, please write back and let me know.
This would be a shorted relay RY1 on the control board.
There are two options for this model:
- You can order our exclusive modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
For details, see: http://www.microwavedisplay.com/exchange.htm
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. "Ed" Miller, AS-EET
prototech@usa.net
Jan 18, 2009 | Dacor DMT2420SS Microwave Oven
Model #mh7130xe made grinding noise then in line fuse blew
Did you replace the fuse yet?
Did the new one blow?
If so, and if it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If so, and if if it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the new one did not blow, and the microwave still makes a growling or grinding noise, but does not heat, you probably have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 05, 2008 | Whirlpool MH7130XE Microwave Oven
Amana mvh230 microwave
Hi there!
The magnetron has probably failed. Check the High Voltage Diode for short circuit. Replace protection fuse with same value. The Diode is standard on most microwaves. Magnetron to be replaced with the same profile and wattage. Be sure to unplug Mains before opening the unit. Good Luck, JUS004
Feb 28, 2008 | Microwave Ovens
Microwave troubleshooting...
My GE spacesaver microwave all of a sudden stopped heating up things. The lights, fan, turntable, etc. work, but nothing is heating up. Any suggestions?
Oct 23, 2007 | Whirlpool GH8155XM Microwave Oven
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
KitchenAid KHMS145J Microwave Oven Logo
96 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
