Question about Siemens Refrigerators
KU15RA50GB - iQ100 Built-in fridge stopped working the back of the fridge defrosted, i moved the unit where the light and temp dial are situated and the fridge started to work again for aprox 24 hrs then stopped working again, i tried to move the unit about again this time to no avail! any ideas what could be the problem?
    President:
  • 1,891 Answers
If the frig keeps frosting then it must have a defrost problem as the nofrost ref do not have frost . i thim=nk that moving the frig is only looking like it changes things but the problem still is in the no frost system .. mm
Posted on Sep 01, 2010
Hotpoint F1810p not functioning after ice buildup
Normally when there is a frost build up, the defrost timer is not working properly. The fridge will not run when in defrost. Some of the newer refrigerators have printed circuit boards that control the operation. Most older units have a separate timer that controls the defrost cycle.
May 04, 2015 | Hotpoint Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Fridge stopped working
Sounds as if the unit is stuck in defrost. How old is it? Look for mechanical {twist} timer and turn it until it starts. If it is a newer model unplug unit for 1 minute this might reset control board but you'll have to know if it is either mechanical or Automatic defrost!!
May 27, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Kenmore Side by side unit has stopped working
turn both dials to 5 and wait for an hour, when it first conmes on they go into a defrost automatically, the defrost controller isa in the upper left hand side of the refrigerator compartment and may be an adaptive technology one that is just a circiuiot board thats about 4 by 4 and behind the area thats betwqeen the back dammper and the front of the unit. It may have fried and that wopiuld explain why your frig does not work.,
Mar 26, 2009 | Kenmore 51572 / 51574 Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Power Problem
You will certainly have to replace the thermostat. Typical problem is once temp. is reached, it takes forever to come on.
Feb 29, 2008 | Frigidaire FRT8B5E Top Freezer...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
193 people viewed this question
Top Siemens Refrigerators Experts
marlin siecinski
David Ellis Rhea
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
