Question about Dishwashers
My Heller HWD12 was working ok then wont start.No water seems to be going in.I have no manual.
We have the same problem....buying another make if we can t get a fix
Posted on Oct 04, 2011
I see the usual reply is go to Heller Im asking because there is no answer at Heller. I need a manual for a Gusty 10CO portable air con. I have searched Google ALL DAY.I need a better reply please
I did a google search and found only one link (below). I don't know if it is a con or a genuine manual.
In the absence of a dedicated manual you will have little choice but to gather information of a more generic type and apply it to your air-con. I expect most of them use the same working principle and similar component arrangement.
http://dattorrent.com/search/heller+portable+air+conditioner+model+gusty10co+m
Apr 01, 2017 | Heating & Cooling
Heller breezy 15co
I have a manual for this machine. what is your question?
Jan 04, 2014 | Heating & Cooling
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
When my portable Heller Gusty 10CO air conditioner is turned on to air conditioner it shuts itself off after 30 seconds but will work on fan mode with no problems. I do not have the manual for it and am...
We have this same AC. To drain the reservoir completely, you need to tip it backward, basically until it's parallel with the floor. Kind of silly, but yeah. After draining, you want to run it on fan for a while (we leave the reservoir plug empty while doing this), which should evaporate out any remaining water.
That said, we still may only get a few hours out of it before needing to drain it again.
Dec 11, 2010 | Heating & Cooling
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Instruction Manual for HELLER automatic timer
hi can you tell what the cool or the hot pic are
Dec 07, 2008 | Hardware & Accessories
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Dishwashers Logo
147 people viewed this question
Top Dishwashers Experts
