Question about HP Photosmart 945 Digital Camera
HP 945 lens stuck out, red light on steady, white screen
I was taking pictures with the camera when it locked up. The lens is out, and wouldn't retract. I couldn't get the camera to respond, so I took the batteries out. When I put them back in, the LCD screen turns white, the red light is on steady, and nothing happens. Power button has no effect. Have let the camera sit with no batteries FOR DAYS! Have tried 3 sets of new batteries with no change in response.
  • 11 more comments
  • kewabl May 18, 2008
    exact same situation with my hp 945. also tried connecting to pc by usb but nothing happens.
  • hairem May 26, 2008
    Nope, no noise. I've also tried gently "encouraging" the lens to retract, but it doesn't budge.
  • Anonymous Jun 09, 2008
    I have the identical issue
  • Anonymous Jun 17, 2008
    Same problem Leaving out batteries does nothing
  • mrrogers Jun 27, 2008
    At first the lens stayed stuck in the out position, the screen flashed white and the red light would blink. Removing the batteries for both short and long time did not change problem. Now about a week later, the camera is still stuck and even with fully charged batteries it will not turn on.
  • Anonymous Aug 18, 2008
    Same exact problem
  • Ukon17 Oct 23, 2008
    I have the same problem. Does anyone has suggestions on where to get it fixed?
  • Anonymous Nov 05, 2008
    same problem, don´t buy HP
  • rayusa35058 Nov 11, 2008
    Not exactly the same but very close When I install new batteries the red light comes on and goes off very shortly the lcd screen comes on and goes off very shortly (about 1 sec.) it made a sound at one time, but the few more times I have tried, there are no sounds.
  • Marzidon Jan 03, 2009
    Man i have the the same problem bought the camera off e bay in 2005,just used it for a month & it suddenely froze.up to date when i fix the batteries its the same.
    is there anything else that can be done. I kep wishing the darn thing will just work suddenelry when i try it once in 4 months
  • stokely418 Jan 23, 2009
    I've had this HP Camera for years. It really takes (took) great pictures until I dropped it on the lens. The lens looks a little crooked :( . It tries to turn on and i can hear the lens try to retract but nothing happens. Is there a wiring diagram online that i can look at? I ordered an old used camera which still retracts...any suggestions on how to take apart correctly and does this type of camera cause a shock even if it doesn't have the batteries it it? I would appreciate anyones help. Thank you
  • Anonymous Mar 01, 2009
  • Jason Adlard May 11, 2010
    any noises coming from the lens when you power it up?
    Novelist:
  • 153 Answers
Ok, here's a couple of long shots to try...
If there is a backup battery remove that also and let it sit for some time with the power switch in the on position (if it has one)
also check the battery contacts are clean. Refit both batteries and try again.
Beyond that unfortunately it sounds like a main board failure. If you have any warranty on the camera return it, if not its likely the cost of replacement would be fairly high but worth checking with HP.
If your handy and fancy a go at it yourself it may be worth opening it to check nothing has become dislodged, but this is unlikely. else pick up a faulty one off ebay, one with a broken LCD or lens and have a bash at swapping the main board out yourself.
A WARNING ABOUT OPENING DIGITAL CAMERAS THEY BITE
Before opening a digital camera its recommended you let it sit for some time (like a week) with no batteries in. There ia a large capacitor (like a battery) which can be charged up to 300v if you touch the contacts or anything connected to it it really is like a shock from the mains.. I have been bitten many times...
This can damage the delicate parts within because of high voltages but more often because you almost always drop the darn thing..
Best of luck
Posted on May 26, 2008
I was taking pictures and the camera just shut off. I thought it may be the batteries, so I put new batteries in and it came on but now will not shut off. The lens is extended and the red light comes on...
I have the same problem. If you get a solution please let me know at corsica2001@shaw.ca thanks! It just happened today! Seems all the hp 945's are burning out at the same time!
Oct 12, 2011 | HP Photosmart 945 Digital Camera
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
Hp 945 frosen with red light on
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Camara locked up
Be sure you are using the right kind of batteries in the camera. Check to see if the device requires NiMh, Lithium, etc. It's not just about getting AA size. Alkaline will probably not work properly, and could cause device malfunction.
May 23, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Hp photosmart 945 does not turn on all the way
I think the camera is not reading the battery life correctly....not sure. It indicated I still had well over half the life left. I changed the batteries and all seems to be okay at this time.
Apr 10, 2008 | HP Photosmart 945 Digital Camera
Whitebalanc; red cast over pictures
Greetings...
The red or orange cast comes from a warm light source since you have the auto white blance off...
Got to your menu and turn the auto white blance back on and then try taking the same picture under the same lighting and see if that corrects your problem...
Ed
Apr 08, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Camera won't work
HP technical Support is the 1st place to go - in case there is a repair/replacement solution. If the camera is over a year old - an economical repair is unlikely
Jul 09, 2007 | HP Photosmart 945 Digital Camera
HP Photosmart 945 Digital Camera Logo
716 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
