HELP WHY DOES MY TV VOULM GO DOWN BY ITS SELF
    Genius:
  • 1,224 Answers
Little gremlins in your flat panel
batterys in remote could be low or the volume button from factory sticks every now and then and says hey im going to mess with you today
or its controlled sound on the circuitry that has a signal interupt lead that when a signal interferes it turns it down its self
Posted on May 10, 2008
How do I reset my sinotec TV without remote?
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. ...
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds.
You should have its original remote control to unlock it. No universal remote control will go.
Nov 16, 2016 | Televison & Video
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Sound but no picture
did you do the self check for errors this set has? you can click the make a comment button and reply if you need help.
Dec 21, 2012 | Mitsubishi WD-65738 DLP TV
I have a rca xl100 commercial tv and have forgotten the parental password.please help
Hello
To unlock RCA TV, try the following.
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
May 14, 2011 | Daewoo DTQ-13P2FC 13" TV
RCA 32v550t. The parental control has been accidently activated and i can't figure out the code. The front panel has also been locked please help me.
Hello Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works
Nov 20, 2010 | RCA 32V550T 32" TV
I am trying to set the self timer, can anyone help me with that?
Self timer is not available in AUTO mode.
Please check the other options ( As I do not remember the other right now)
Select the other options available (eg: Tv,Av etc) and hit function key and scroll down.
In the self timer it self you can also mention how many shots you want to take.
Also you can see teh manual. In the last pages it is being under teh section Self timer.
Jun 15, 2009 | Canon PowerShot A520 Digital Camera
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Aug 14, 2008 | Sony KP-53HS10 TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Re: Vchip code
you need is factory setting!
Oct 05, 2007 | Panasonic PV-C1321 13 in. TV/VCR Combo
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
