Question about Electrolux Washing Machines
Electrolux Kelvinator washing machine, modal 960 SSX , 6.0 Kg. drain water not broket, Please give supplier contact number near Rajahmundry, East godavari district, Andhrapradesh state,India.
3 Suggested Answers
  • 6277 Answers
SOURCE: I have a Washing Machine
Sorry, this Washer Forum does not supply engineers or spares; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
If this has clarified the situation and/or assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 29, 2011
  • 6277 Answers
SOURCE: We have a Electrolux Kelvinator
Hi (again!) from retired Englishman in SW France,
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
Fails to drain the water?
could be the pump that has got jammed, try clearing it by removing the filter housing.
if you need help on the best way to do this, please dont hesitate to contact me
May 19, 2014 | Washing Machines
Electrolux Inspire 7 kg washing machine. Error code 22. A program run for 30 minutes Ok and the stop and reset the program. What means e22 and how can be solved? Thanks in andvance!
Hello Serban Alexandru - Typically error code E22 indicates that the water is not pumping out fast enough. Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have the pump, timer or main control board diagnose.
Oct 04, 2012 | Electrolux Washing Machines
I have a Washing Machine of Electrolux Kelvinator 960 SSX, it was creating problems for last 3 days. pls. share the contact details & service center address of Lucknow.
Sorry again ;-0(
John C
Apr 29, 2011 | Washing Machines
We have a Electrolux Kelvinator 960 SSX, last 3 days it was creating problem. i need to know the contact details & address of service center. Pls. share ASAP.
Sorry again ;-0(
John C
Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Aug 03, 2009 | Electrolux Washing Machines
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Electrolux EW 1005f washing machine trouble.
http://jaipur.justdial.com/washing-machine-part-electrolux_Jaipur.html
click this link for eltrolux parts in jaipur
http://delhi.justdial.com/washing-machine-part-electrolux_Delhi.html
click this link for parts in delhi
http://machines.exportersindia.com/cleaning-equipment/washing-machine-parts.htm
click for all other leading part suppliers
http://govindenterprises.tradeindia.com/
click the link
GOVIND ENTERPRISES RZA/337, Nihal Vihar, Near Guru Harkrishna Nagar, Delhi - 110041, India
Phone:91-11-25943604
floating-close.gifContact Now
floating-sendmail.gifSend E-mail floating-callmefree.gif Call Me Free
Key Personnel Mr. Bhupender Singh (Proprietor)
Mobile:+919212646376
Mar 26, 2009 | Electrolux Washing Machines
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Electrolux Front Loader 7 Kg Error Message E20
From the manual E20W Problem with water draining
Sep 14, 2008 | Electrolux Washing Machines
Washing Machines Logo
125 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
