Question about Toro& Electric String Trimmer
How do i remove head trimmer on a toro 1100 heavy duty trying to restring cant get head off i see 2 clips on sides dont know how to remove
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: It has come apart and I would like to refill the
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jun 25, 2009
Toro tb65ss upper string head removal
  1. Pull the spark plug wire from the top of the spark plug. Bend the wire to the side to prevent accidental starting.
  2. Place trimmer on its side with the trimmer spool head facing you. Press the two tabs on the side of the spool head with your fingers.
  1. Hold side of the head and slowly allow the head cover to push away from the inside of the spool head. There is a spring between the spool head housing and the spool that pushes out when releasing the cover.
  1. Pll the knob and spool out of the spool head. The spring should come out on the back of the spool.
    Electric Trimmer
  1. 1 --> Unplug the Toro trimmer power cord from the electrical outlet.
  2. 2 --> Lay the trimmer on its side. Hold the spool housing tight in one hand and twist the cap counterclockwise with your fingers. If necessary, use a pair of large slip joint pliers to start turning the cap. The cap is the center piece of the spool.
  3. 3 --> Pull the cap off the spool and remove the spool from the housing.
Apr 26, 2014 | Garden
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
Need help restringing it
For starters, if you don't have the original, in-the-box trimmer thread, you should get the appropriate diameter. Ez enough, you just need .9 to .10 diameter thread are somewhere around that diameter.
Which attachment are you trying to restring, there are several. One will have holes for a "fixed string" with a label that says "stop" on it. This is the fixed string attachment head. Take a piece of fix string, these are pieces of precut string that come with various other tidbits in the box, about 10-12 inches long. insert the string through the head the inserted end comes out the other side. Pull that end out to the edge of the "stop" label. Repeat the process for the metal hole on the other side. That's it, now you are ready to go.
The other trimmer head is a bit more difficult. Unscrew the top sleeve to expose the bare, 2 chambered core - have replacement or original thread ready to go (same diameter as mentioned previously). Once you have removed the top, notice that there are two holes with notches in between the 2 thread chambers. The notches will indicate which chamber you will be sending the thread that will be coming through the holes. Have the thread ready to go, and insert one end all the way through the hole on one side and then out the other. Now you must get the string ends coming out more-or-less equidistant from the two attachment holes so that you get an equal balance of thread being fed out of the head - either with helper holding the attachment head or by just hooking the attachment head around a pole or something, pull the 2 threads through to get them equidistant.
Once you've done this, follow the notches at the respective holes to wind the thread into the proper chamber, as if it were fishing line. Finally, put the head sleeve back
For the other trimmer head
Aug 18, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Can not figure out how to restring
im pretty sure i have the same trimmer, take the spool off, take all the cord out of it, now look closely at the bumper, u should see an arrow, find the halfway and fold it so it 2 peices, dont cut it, and rewind the cord, ull see clips on the bumper thats for when ur finished itll hold the line back in place so u can put it on without hassling with the cords, once u get the bolt on and tightened, give those 2 cords a good pull and they will pop out of the clips and u should be good to go, if this doesnt help ya, there is a tutourial on fixing these on youtube.com
May 08, 2009 | Homelite Mighty Lite Lawn Trimmer
Toro& Electric String Trimmer Logo
250 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
