Question about Intel Computers & Internet
I changed my os my dvd drive s not responding to any cd or dvd
  • 382 Answers
You should update your BIOS, drivers and firmware for the drive.
If the OS is picking up the drive and your sure the discs are OK then it could be a simple lens clean is required.
Posted on Sep 06, 2010
Format aspire4736z
Hi there.
To format you will need:
Operating Systems (OS) CD/DVD
Steps:
1) Enter the BIOS when the laptop boots by pressing the Delete key repeatedly.
2) Once the BIOS is open locate the boot disk priority and set prioity 1 to the CD/DVD drive, set priority 2 to the laptop's hard drive.
3) Save changes to the BIOS and exit. The system should now reboot.
4) Insert your OS CD/DVD.
5) Press Enter when the system asks you if you want to boot from the CD/DVD.
6) The OS setup should now start, the first thing it will ask you to do is format your hard drive.
7) After you drive is formatted you can either continue with the setup and install a fresh copy of the OS or you can exit leaving the main drive clean.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
I have a HP XW4100 with Windows 2000 and want to upgrade to XP SP3. I purchased a XP OS Disc from Microcenter as well as 2GB of extra memory. Memory install went fine. When I try to load XP, the machine...
When your computer is starting up there should be a button to specify a boot device. In most cases this will be F8, F10, F11 or F12.. make sure you watch the startup for details. Also.. keep an eye on it while it's starting up because sometimes a small message will appear saying:
"Press any key to boot from CD.."
in which case you need to quickly respond by pressing any key. This message only appears for a few seconds so make sure to watch for it!
Mar 30, 2011 | HP XW4100 GCR-8483B 48X IDE Crbn CD-Rom
Dear sir, i have a dell inspiron 5010. when i enter my back up dvd, it shows error as 0x400110020000100a. what do i do now? please respond....
This is normally caused by trying to use a recovery disc on a hard drive that has been wiped of the original OS or where a new hard drive has been installed. The recovery DVD is specific to the particular laptop and will not repair an installation of windows if one does not esist.
Did you change the hard drive at all?
You should try using a copy of a windows CD and use that to do a repair install, inseerting the COA number when asked
The error message can also point to a damaged hard drive, or damaged connector between the hard drive and the motherboard.
Jan 29, 2011 | Computers & Internet
Changing d language from japanese to english
put Os cd or dvd into dvd\cd drive.
go into controll panel.
choose region and language ( the globe picture)
choose language tab.
you can change display and keyboard language of your OS.
Jan 08, 2011 | Computers & Internet
It says my DVD is working properly but I cannot open the drive....I manually opened the drive and I can't close it without doing manually also. the light comes on but it is not responding.
check the dvd drive and see if there is any damaged on its plastics that may cause the issue. make sure the drive tray is not being stuck and nothing is preventing it from opening or closing. next, try to remove and reconnect its power and data cables. Using different cables if available may also help. if using the eject button works, but not through the OS, a possible reinstall of the driver, the firmware and even of the OS may be necessary. if all else fails, there is a chance that you may need to get a drive replacement.
Sep 05, 2010 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
LG DVD/CD RW working with DVD but not with CD
your dvd rom's lense were damaged so if it is in warrenty period then go to servce centre for repair otherwise go to local repair for changing of dvd lense......
Feb 06, 2010 | LG (GDR8164B) Internal DVD Drive
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
LG SecurDisc Super Multi internal DVD not working properly
Dear Friend,
You can try this method, firstly u will do right click on my computer at desktop. here is method for doing this thing: right click on computer------->properties-------->hardware-------->device manager------>right click on your burner drive-------->properties----->driver------>uninstall. GO back to the device managger window, click 0n "action" and then on "Scan for hardware changes". The OS should find your burner and install back its drivers properly. right click my . GO back to the device manager window, click 0n "any drive" and then u will see a option on the bar at above "Scan for hardware changes". then click on "Scan for hardware changes", The OS should find your burner and install back its drivers properly. but if your internet is connected then it is very good. Then u will latest drivers & internet search & update the firmware also.
for any type of drivers u can check this website also: http://www.softpedia.com/ , here u will get any type of softwares @ totally free, you have no need to pay any thing.
Thanks alot,
Sanjeev Suri
Jan 02, 2009 | LG SecurDisc 20x Internal Double-Layer DVD...
Cd drive doesn't see sims 2 double deluxe
I tried the sims 2 game on another computer, which has vista home premium OS. The same problem occurred on that computer. I wonder if the game changed the registry and prevents the game from being reinstalled.
Nov 19, 2008 | Video Game Consoles & Games
Cd or dvd rom drive
This might be due to a registry problem. Re-installing windows (OS) or repairing your OS installation can help. You can install from any previous back up or get the installation files in a USB storage device like pen drive.
You can also try the following which have worked .. insert the OS installation disk in the cd-dvd drive. restart Pc. change boot device option. installation of new OS begins. this is a hit n trial method, but has worked earlier.
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
