Toshiba cx36H60 remote problems & black square in the middle of the picture.
We purchased this tv in 1999. We have had no problems with it until a few weeks ago. Now there are 2 problems. The first problem started a few weeks ago. The remote would intermittenly work. Non of the functions would work changed the batteries but it did not solve the problem.
The second problem is a black square in the middle of the picture. It seems that after making adjustments in the menu box. The box doesn't disappear. There is no way you can watch the tv like this. What do you think?
  • Jackie 8 Aug 24, 2008
    The black square in the middle of the screen has been resolved. I contacted Toshiba and they came up with thea solution. It was so simple, It has been a while see if i remember. It had to do with the close caption feature, and was resolved by turning it off or changing the setting.
    The remote problem was cured by changing our cable service. We just hapen to change our cable service around the same time. Which brought in a cable box and the remote that works with the box. So we don't use the remoted that we were having trouble with anymore.
    Good luck
Same problem with tv ...cant figure it
Posted on Aug 24, 2008
  • abc4878 Sep 16, 2010
    ok I have a toshiba 36" crt tv from 2001and randomly a black square appeared in middle of the screen. It would go away when I changed the channel, increased the volume etc. but would come back in a few seconds. Jackie8 's solution worked, I went into closed caption "CC" settings and turned it off, it was set to T1. This corrected the problem.
I have a toshiba model CX36H60 and the picture keeps going black. I have the hit the menu button on the remote to get the picture back. This is happening every 3 to 4 minutes. When I get the picture back...
Your tv has a defect ,maybe in the board, maybe its only loose connection. you need to sesolder all the parts in the main board .but you need a qualified technician to fix your problem.
Jun 28, 2010 | Televison & Video
Black square in middle of picture
your captioning or "text" is on. usually inside the tv menu. if not its your cable or dish box has captioning on. black box usually means its in text mode instead of CC thus the black box rather than text
Jun 03, 2009 | Televison & Video
Black square in picture .....
Try picture in picture button on remote?
Dec 27, 2008 | RCA Universal Remote Control
Toshiba CX36H60 Cold start woes
check the capacitor in the SMPS and around Mr. Flyback
Nov 13, 2008 | Toshiba CX36H60 TV
Toshiba cx36h60
check the sound section if there's a 12volts supply of the sound ic or check the speaker.
Jan 09, 2008 | Toshiba CX36H60 TV
Black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
Dec 10, 2007 | Hitachi 50FX20B 50" Rear Projection...
TV screen
make sure you lock the setting menu.
Sep 06, 2007 | Hitachi 27UX01B 27" TV
Toshiba model Cx36H60
Yes, I have been seeing a lot of those Toshiba IR receivers bad lately. Replacing it with a new one should take care of your remote problems. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Toshiba CX36H60 TV
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Black squar in the middle of tv after a few minuetes of play.
Turn off the closed caption on the remote or in the setup menu.
Jun 13, 2007 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
Televison & Video Logo
487 people viewed this question
Top Televison & Video Experts
