Question about Gateway MX6025 Notebook Computer (PCMX6025) PC Notebook
My gateway mx6025 is displaying no battery is detected and it can only charge when it off, I thought it was the battery, but since i charge it for over two days, it display 100% charge on the battery charge level itself, now what could be the problem
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 08, 2010
Gateway ma2 mx6027 not turning on help?
Find another charger and try again! You may have a dead battery and can't get the unit to work because the charge is bad.
Nov 25, 2013 | Gateway MA2 MX6025, MX6027, MX6028 Laptop...
I installed windows 7 but there's no sound, the system model is(mx6025)
Have you tried to install the audio drivers? DriverPack Solution (DPS) is the best driverpack package there is. Also it is open source & free of charge. The new version is out. http://drp.su/download.htm
Mar 19, 2013 | Gateway MX6025 Notebook
Power adapter is good, but Gatway MX6025 will not power on. It does power on briefly with battery installed. I've tested the ac adapter with a multimeter and it appears to be good. Green light on,...
Try to check with another adapter if possible.
The connector of the laptop might be damaged. so the battery is not charging and also not staring laptop on AC power. Check the ac connector of laptop.
Jun 08, 2011 | Gateway MX6025 Notebook
Is there any manuals for disassembling a gateway mx6025? any were I can get a chassie cheap?
you will find the schematics diagram on gateway site and ebay is your best bet for a cheap chasis
Aug 02, 2010 | Gateway MX6025 Notebook
Can the wifi b/g be upgraded with the MIMO 3 802.11n Intel 5300 Wifi Wireless WLAN PCI-E Card? George
You can install that card on a gateway mx6025..
It wil work properly, just be sure to disable the onboard wireless card after you install the pci express card so they dont conflict..
Oct 30, 2009 | Gateway MX6025 Notebook
I have a mx6025 gateway notebook. I installed
When i checked, i can only find the Conexant Audio Driver Version: 6.14.10.0565 for this model.
Is that the driver which u tried?
Oct 04, 2009 | Gateway MX6025 Notebook
The battery seems to get zapped very quickly. it is also to get the battery to accept a charge.thank you rick
This sounds like either you have a dying battery (3 years or older would be my guess) or the powerjack on the motherboard of your laptop is defective and no longer conducing electricity to the system adequately. I would start there. Good luck -Carlos:
Jun 13, 2009 | Gateway MX6025 Notebook
No Sound
I would like you to check this site:
click here
Jul 21, 2008 | Gateway MX6025 Notebook Computer...
Gateway MX6025 Notebook Computer (PCMX6025) PC Notebook Logo
492 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
