Hi, have samsung wf8500nhw washing machine. its displaying error Uc. what does this mean and how to solve it? Thanks.
  • send2vj Oct 28, 2010
    Service person said it is also related to unbalanced load... caused due to placing the machine on un-leveled floor/stand.. it was placed on a stand and the legs were not balanced properly
Maanita
  • 1142 Answers
SOURCE: washing machine
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Posted on Jun 23, 2008
SOURCE: samsung b1245s washing machine
Error code is actually 5e and is to do with your drainage being blocked. Check the flap in the lower right of the machine. Open and unscrew the big black wheel/cog thingy (make sure you get lots of towels or drain all the water first with the little pipe to the right of the big black wheel/gog). I found a few coins trapped in my pipe and its working a treat now I cleared them out and spent them on lots of sweeties. Yummy. :D
Posted on Aug 19, 2008
SOURCE: bosch washing machine error code
e04 error not draining door won;t open
Posted on Oct 22, 2008
  • 4 Answers
SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Posted on Apr 17, 2009
backwoodsctr
  • 169 Answers
SOURCE: hi our washing machine keeps displaying error code
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Posted on Nov 21, 2009
How to solve error code 2h for samsung front loader
If you wish to get some details; visit the site linked here. Pull up older posts.
Sep 04, 2017 | Samsung Televison & Video
Please how do I resolve error code UC on my Samsung diamond drum washing machine?
Washing machines have computers. They are literally designed for no ''DIY.'' Error code would likely mean ''new computer needed.'' Either way, you need a laptop with a factory testing program installed in it That's how these guys work nowadays. The laptop tells them what to do next, and you (and I) can't have one.
Aug 15, 2015 | Samsung Washing Machines
How do i make my samsung diamond washer model WF8500NHW use more water in the drum when washing a load
The amount of water in a washing machine is measured to be the optimal amount. If the clothes do not clean, perhaps you should reexamine the powder.
Feb 14, 2015 | Samsung Washing Machines
My sumsung washer is showing an error (Uc) dont know what to do with it, if you have a solution it will be appreciable.
The UC error code represent a malfunctioning main PBA or a power fault related to an electrical power supply that is incompatible with the Samsung washing machine.
Contact Samsung service department!
Jan 02, 2015 | Samsung WF337AA Front Load Washer
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
What is mean Uc error in samsung washing machine WF8550NHW model?
my samsung washing machine paused becuase of the power voltage is not instable. what should i do?
May 12, 2010 | Samsung Washing Machines
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
131 people viewed this question
Top Washing Machines Experts
