Question about Refrigerators
My Hotpoint BL11 integrated fridge wont chill even with thermostat turned up full. Please help.
    President:
  • 1,891 Answers
Look for frost build up in back of freezer and if so you do have a defrost problem and the air flow is restricted causing poor cooling mm ,,
Posted on Sep 01, 2010
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Hotpoint fridge RLA30 frozen milk on lowest setting
sounds like you need a new thermostat for your fridge. If your fridge wont shut off on its own than yes its most likely your T-stat. Hope this helps
Feb 15, 2013 | Hotpoint Refrigerators
Hotpoint ff73 fridge temp unstable some times ok other times not chilling at all temp gauge showing different reading and freezer sometimes drops down to minus 30.in the cabinet
Possible that the thermostat is faulty or there is a weak connection due to frost wearing- out the connection of the thermostat. Shut down the fridge and allow time for the frost to melt off, then check the connections of the thermostat and to the defrost timer, open the freezer rear panel to check this out.
If not the main relay also must be checked, Hope there is no interuption of the mains power.
Sep 08, 2011 | Hotpoint Refrigerators
Hotpoint RLA30s Freezing!
check the ptc overload relay it could have stuck and is supplying power to the compressor all the time even if the thermostat is off,its on the compressor body where the wires go to the compressor
May 11, 2010 | Hotpoint RLA30 Compact Refrigerator
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Hotpoint not chilling
looks like your compressor is busted. the sound that is not healthy is the compressor trying to start, as you have said, chugging... now everything is hot since the compressor is no longer running. have a qualified tech check it to see if the compressor could still be saved...it might just be a dirty condenser.
Dec 15, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
