Question about Maytag Chassis Built-In Air Conditioner M7X05F2A
Maytag AC afternoon out to lunch
My 3 year old maytag 5200 room unit recently does not kick in Air condition in the afternoon, but works fully at night and morning hours???
  • Anonymous Mar 14, 2014
    Hello, I've got a temperzone ducted air conditionning and this afternoon the wall main screen indicated -9 degres celsius ( it's arround +28 degres now). , so the AC won't start anymore, anyone can help ? Thanks
  • 54 Answers
Clean the condenser coil and change the filter.
Posted on Jun 09, 2008
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
The condenser unit will not kick is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
I cannot get my wintair room air conditioner to stay on! It keeps cutting on and off, going from fan to air conditioning. Need help!!
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Jun 28, 2010 | Heating & Cooling
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Anybody there?
It depends on the room varables, If it has an attic, tile ceiling, what type of walls, where in the building is the room and so on? The biggest problems is all ways the power. Get a free estaimate from an A/C company. Everyone and myself needs to see the room before they give you an recomndation that can truly be applyed to your situation. But to give you some ideas, I would put a 2.5 ton - 3 ton unit just for over kill. Go with a straight cool package unit. If your company tight on cash just get a mini split system with a 30,000 BTU to 36,000 BTU cooling capacity. Cost for something thats going to last 20 years, avg. is $4,500- for the package unit and as low as $3,000 for the mini split.
Oct 17, 2009 | Frigidaire FAA055N7A 5200 BTU Room Air...
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Air condition cleaning
hi! there,
if your unit is almost five years from now,its more convenient to have a maintenance schedule every two to three time a year,if this a windows type,cleaning of ac unit mostly the eveporator and condenser should free from dust,upon installing,the a/c unit should be eleveted down on condenser,the tray should have a drain with hose to drip the water outside your room,so that water will not leak on your light,see this may cause electrical fault resulted on burning.have always clean the filter.try to inform the maintenance crew to elevate the condenser portion down gradually so that water will drip outside the room.have anice day,don't forget get to rate me,and thank's a lot.
Apr 26, 2009 | Heating & Cooling
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Just tell me if you have a single unit or a split unit,I can help you with this problem,but need to know what you have..
Waiting for your youre reply.
Sep 10, 2008 | Heating & Cooling
Maytag M6Q10F2A window A/C unit about 4 years old
buy a new effecient A/C
I had the same problem but it was my bedroom one so I swapped out my living room A/C into my bedroom and put the new one in the living room.
Jul 17, 2008 | Maytag M7Q08F2ACOM Air Conditioner
Maytag Chassis Built-In Air Conditioner M7X05F2A Logo
189 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
