Question about 2wire (1000-000057-000) Modem
I want the wireless light to be on. its the only light thats off
How do i set up wireless?
How do I turn on the switch?
Posted on Sep 12, 2008
If all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire modem.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
Posted on May 11, 2008
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you successfully connect to Xbox LIVE, you'll see this screen:
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
Blue wireless light wont come on, so I dont have wireless interne
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jul 13, 2010 | Belkin Wireless Router
WLAN light will not go on
I would advice you to perform a factory reset on your unit if you think the wireless light is completely and your wireless computers are not connecting wirelessly. Factory reset will delete all your settings and you need to set up the internet back.
You can also try power cycling the unit. Turn if off for 2mins and then power it on , then observe the wireless light.
There is also a possibly that the wireless light is just dim. You can check your wireless computer if they are getting a signal from your router. If they are getting a signal, that means the wireless light is not properly light up.
Please give me an update to your concern. So i further assists you
Kj
Jul 04, 2010 | CP International WBR-6000 Wireless Router
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :)
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
Unplugged my router. I plugged it back in and it was no longer broadcasting signal. Wireless light is not lit. Tried unplugging again and did a hard reset and is still not showing up on my connections even...
Please try opening the setup page of the router from web browser http://192.168.1.1 and username is blank and password is admin then go to wireless settings and there you will find option to turn the wireless on once the wireless is ON on that page save the settings and then close that page, switch off and switch on the router the wireless light should come on.
Also even after that if you are not able to get wireless light on try changing the wireless channel used, try using channel 1, 9 and 11 as they are interference free
Please let me know if this will help
Regards
Jan 06, 2010 | Linksys WRT300N Wireless Router
Having problems hucking up to xbox live
Okay so here we go!
Now go back to "Network Settings" and select "Test Xbox Live Connection"
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Dec 25, 2009 | Microsoft Wireless Network Adapter Xbox...
How can i turn the wireless on? the led for wireless is off?i cant find any switch except for the reset.
The wireless part of a router (AP = Access Point) is normally "switched" on or off by way of a setting in the routers configuration - check your owners manual on how to do this. There is no physical switch as such.
Also, the wireless light only lights when a wireless device has established a wireless connection to the AP. Even though the AP maybe enabled and working, until a wireless device connects, the light remains unlit.
I dont know this exact model of router so cant give specifics on how to set it up, but hopefully if you can find your manual, this gives you a starting point.
Oct 31, 2009 | Creative Labs Network Blaster Router
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
2wire (1000-000057-000) Modem Logo
584 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
