Question about LG LB8000ER Air Conditioner
Electical my unit is less tan a year old and will not turn on checked breakers and the breaker on the plug itself
    Scholar:
  • 149 Answers
If its electronic controls verify the fuse if it's manual controls the selector switch shorted out.
Posted on May 09, 2008
3 tv' s in my home stopped powering on on the same day. I have a 46" and 60" plasma' both less than a year old and a 27" LED. I checked the breakers. I unplugged and plugged them in again. Al
Your tvs sensitive ic chips on the power boards have been subjected to an undetected voltage spike and are fried. I'm guessing that none were plugged in to a surge protector?
Apr 20, 2013 | Panasonic VIERA Televison & Video
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Breaker malfunction- Breaker won't restore power to the circuit
To do this safely you should call an electrician. No way I can give you complete instructions that will be sure to be safe because I can't see exactly what the situation is that you have. But the basic steps include: turning off the main, understanding that you are about to expose the feed lugs TO the main which are still LIVE (and giving them a wide berth!), carefully removing the cover, CONFIRMING that everything else in the box is NOT LIVE (use a non-contact voltage detector - $15 or less), removing the wire from the old breaker, pulling the old breaker out, plugging the new breaker in, connecting the wire to the new breaker (nice and tight), replacing the cover and then turning the main back on.
Jul 27, 2010 | Cutler Hammer Eaton Electical #BD3030...
Electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Dec 15, 2009 | Amana AER5715QAS Electric Kitchen Range
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
AC tripping breaker.
Check its wiring connection. Could be loose connection, corrosion.Or the breaker is already retiring. If the breaker is fairly rated to the aircon unit. Also insect could be the culprit.
May 25, 2009 | Goldstar GW-HD5000 Window Air Conditioner
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
Aug 22, 2008 | Whirlpool AD65USL / AD65USM Dehumidifier
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Sep 11, 2007 | Heating & Cooling
Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Apr 08, 2007 | Maytag PYE2300AY Electric Dryer
LG LB8000ER Air Conditioner Logo
64 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
