Question about Lexmark C524 Laser Printer
Spots when printing
When I am printing color images to my Lexmark C524 I am left with spots of blue and red on the image and the rest of the page. This only started recently and I don't know how to fix.
    Novelist:
  • 170 Answers
It sounds to me like you may have 2 low or defective toners, the Cyan and the Magenta. If you have another machine like this available to you try swapping these 2 toners out to test the theory or you can take these 2 toners out and spin the drum manually (by only touching the gear) checking to see if the spots you see on the pages correspond on the applicator roll of the toners...
Posted on May 09, 2008
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
HP 2550 L ...When I try printing in color...........I get red/magenta spots on the printout........why is this happening ?
Are the spots in a uniform pattern? Try the Magenta toner cartridge first, the try replacing the imaging unit.
Jun 26, 2011 | HP LaserJet 2550L Printer
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
Full Cyan Cartridge Does Not Print At All in Lexmark C524
It could be that your PC is expired
"Photo Coductor"
Apr 28, 2009 | Lexmark C524 Laser Printer
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Im running 12"X18" sheets from the manual feed tray..
You should print the "Repeating Defects Page" Using the printer's front panel menu keys perform the following steps:
  1. With Information highlighted, press the OK button.
  2. Scroll to Troubleshooting by pressing the Scroll Up or Scroll Down button.
  3. Press the OK button.
  4. Scroll to Print Quality Probelms by pressing the Scroll Up or Scroll Down button.
  5. Press the OK button.
  6. Scroll to Repeating Defects Page by pressing the Scroll Up or Scroll Down button.
  7. Press the OK button to print the Repeating Defects Page.
Most likely you have a defect on your magenta imaging unit. Switch the Magenta and Cyan imaging units and try the test print....if you have blue spots 3 3/4 then it is the imaging unit (drum). If not you may need to change the belt cleaner assy.
If it isn't the imaging unit then it will be a problem with the fuser rollers, so replace the fusing assembly.
Jan 15, 2009 | Xerox Phaser 7750DN Laser Printer
Smudges lexmark c510
First check the rollers of the fuser assembly and drum are free of any greasy spots as if somebody touched them with dirty hands. if they are clean, you may have dirt on the lenses inside of the laser imaging compartment and to clean you must be careful not to scratch them or move them out of alignment. moving the lenses invites a totally different trouble, and plus they are plastic for some reason maybe it is economical that way use a micro fiber cloth only.
Aug 05, 2008 | Lexmark C510n Laser Printer
Color marks on both edges of the paper
I had the exact problem. It was caused by a defective photoconductor.
Depending on what colour the spots/marks are, the photoconductor for that toner cartridge needs to be changed.
Jul 01, 2008 | Lexmark C524 Laser Printer
Spots on paper
Look on the image drum (bottom of toner cartridge) are there spots on that?? if so clean carefully so as not to damage it or replace the cartridge. If this is not the case open the cartridge door during a print, but before the paper fully enters the fuser and check if the spots are already there, if not the fuser is causing the problems.
May 14, 2008 | Lexmark E321 Laser Printer
Lexmark C524 Laser Printer Logo
356 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
