Question about Husqvarna Chain Saw 20" Bar
I need a new spool for my spjbc30,who stocks them?
I have a singer featherweight 11 117 model and the spool pin snapped. Where can I get a replacement?
First of all, it's likely at this point that you think your machine is unusable without it, but you're wrong. I have four Singer high-end sewing and embroidery machines, and it has been years since I used their spool pins.
Simply put a coffee cup or--my favorite--a lidless pint Mason Jar at the back of your sewing machine towards the right (away from the fabric side), bend the thread (don't wind the thread) around the remains of the spool pin to use it as a thread guide, and then thread the way you usually do, and you are in business!
Now, to address the replacement issue, there are several places where you can order a new one. Do a search on eBay for "Singer Featherweight Spool Pin" and a number of listings will come up. Don't put in your model number in the search box. If you see that a dealer is featuring one for a Featherweight, but not for your model, don't hesitate to use the "Ask a Question" option in a listing; these are generally quite knowledgeable dealers who can order one for you. Also Jenny's Sewing Studio and Sewing Parts Online either have them in stock or can order them for you. It appears that they are quite inexpensive too!
Aug 04, 2014 | Singer Featherweight II 117
Which typewriter ribbon do I buy
If the spools are 2" in diameter have a 1/8" hole in the center with 4 or 5 smsller holes around it this is a pretty standard fabric ribbon we have them in stock if it is different sem\nd the spools to us and we will wind a new ribbon on them.
DickyO
216-269-3918
Jun 17, 2013 | Olympia Office Equipment & Supplies
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
Elna lock overlock 5 thread sewing machine, the thread guide pole is broken and I need to replace
you should be able to buy this part from either a local Dealer who stocks Elna or from online. try www. sewingpartsonline.com or www.sewusa.com
Sep 18, 2011 | Sewing Machines
I can't find a replacement spool TF065 for my ST6000 trimmer/edger. My husband passed away, and there is no spool in the trimmer. Home Depot says there is none. You just wind it on by hand. I have...
Unfortunately, the manufacturer no longer carries the TF065 for the ST6000 trimmer/edger. No substitute is listed. The TF065 is no longer in stock at any of the parts stores that I checked. The Parts List and direct order information is available here: http://servicenet.dewalt.com/Products/Detail?productNumber=ST6000 .
You can try other Service Centers in your area to see if they have any spools remaining in stock. Use the Service Center lookup tool here http://www.dewalt.com/Find-Service-Center.aspx .
I wish that I had better news for you.
Jul 26, 2011 | Garden
I have a spoolmate 200 ser. JJ373378 stock no. 084878 with a spool gun. i pull tricker wire runs no arc. I don't think main contacts are kicking in.
If you wire runs, then your problem is the power line, check first that you have in hook up to the psotive (+) side of the power source/machine. The spool guns is just a wire feeder, your heat comes from the power source.
Dec 30, 2010 | Welding Tools
I have a honda generator but i change the cordon starter and now i dont now how ensable it, i need a diagrama of this
What you need to do is first remove the new cord that you installed.
(This next process is best performed by 2 people)
Pre-wind the spool gently COUNTER CLOCKWISE until the spring prevents further winding. Have the 2nd person grip the spool so that it does ot unwind. Back off the spool until the re-wind rope hole is aligned with the outer cover rope guide. Insert the new rope through the outer cover rope guide hole and into the spool hole. Pull the new rope through the spool hole and tie a single small knot. Pull the knot into the hole. 2nd person releases the spool and the rope will rewind into the re-coil assy.
Aug 04, 2010 | Honda 3000 Watt Portable Generator
I am after a manual for my Spear and Jackson Petrol Strimmer
You can download this from www.isc-gmbh.info/download/prod/21424791/3401760_01018_SPK1.pdf. The model is actually a rebadged Einhell BG-BC 30/1
Nov 15, 2009 | Garden
Spare parts for spear and jackson strimmer spjbc30
solent tools tel 023 8057 8057
email sales@solent tools.co.uk
Jun 15, 2009 | Husqvarna Chain Saw 20" Bar
Ribbon spool does not turn, TEC B452
If you are working with the driver, change in stock page direct thermal to thermal transfer.
Mar 13, 2009 | Toshiba TEC B-572 Printer
Husqvarna Chain Saw 20" Bar Logo
75 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
