I can't complete installation. The installation process stops at "Installing wireless adapter driver" it stops there for half an hour already. what can i do?
  • 808 Answers
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Posted on Sep 01, 2010
I already installed the right driver for my Wireless Adapter of my laptop but I cant connect to the internet through wireless connection. It say's their "The driver successfully installed used Fou
Did you reboot after install? What does it say when you try to connect? Why did you have to re-install the wireless adapter driver? Did you download the driver from Asus?
Jan 08, 2013 | ASUS Eee PC 1215BPU17BK 121Inch Netbook
How to turn on wireless switch on a desktop
I've never seen a 'switch' on a desktop to turn-on wireless, like there are on Laptops/Notebooks.
Usually it is either a device that is install in a slot in the PC, or it is a USB plug-in adapter. There ARE some motherboards with built-in Wireless ability, those can be turned-On/Off in the BIOS.
You would have to have a Wireless Router/Wireless Access Point in place already, it would need to be setup and security enabled.
Then it would be a matter of installing the driver for the device....WHEN you do that depends on the type of adapter you have:
add-on slot adapter -- Install adapter, then driver software
USB -- install driver software, DO NOT plug-in adapter until directed to do so, or the driver installation finishes.
Tallon41
Sep 18, 2012 | E-Machines eMachines Desktop PC
Won't install on computer
Make sure driver software is installed before ever connecting the wireless adapter. You may need to do a complete uninstall and start over. Or, your PC is not compatible with the adapter. More info would be needed.
May 01, 2009 | Computers & Internet
My installation is stuck at 30%
  • Hey, Have to also make sure the wireless adapter is not plugged while installing (only when prompted to plug it in)
  • You can try downloading a NEW installer from the Linksys website. (maybe the cd is scratched?...) Here is a link to the Driver/installer, for your adapter. (This is a WindowsXP Driver)
  • Try installing the driver using that, and then plug in your wireless adapter when the setup program prompts for you to do so.
Report back if there are any more complications or issues that occur during the above process,
I'll be happy to assist you further.
I Hope This Helps.
Jan 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Dell 1450 wireless adapter
Yes, the driver can be corrupted and you need to reload the driver or better download the latest one and use that instead to make sure your adapter is using the right software for it...
Hope that helps... Don't forget to rate the solution FIXYA thank you
Oct 05, 2008 | Dell 1450 (D1450U) Wireless Adapter
No association with access point
Another thing to check, (especially if you have installed SP2 in the midst of this process of trying to get the Linksys WPC54G drivers  installed).
In Device Manager, check under the "network adapters" category and see if there's any "other" things with a yellow question mark - I clicked one of those, had it search for the new driver, and after a few minutes it eventually installed a WPC54G driver and placed it in the "Network Adapters" category (I had already run the drivers install from Linksys, Broadcom, many times over - de-installing each time to try another version).
Funny thing about it, when I hit "update" or whatever on that yellow question mark icon - it had given me no clue whatsoever that it was a wireless adapter driver that it was updating.
Hope this helps.
Teddy
"Messianic Roots Reggae from Jerusalem" http://www.Yerubilee.com
Jan 28, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless-G USB 2.0 adaptor stops midway through installation
Are you sure the adapter is VISTA compliant? Some are, some are not. BPCS
Dec 28, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
