Question about Cuisinart DCC-1200 Coffee Maker
2 of these quisinarts..
I had one for over a year.. it stopped ginding so i bought another one and after 4 weeks it started leaking.. it leaks so fast that have to make coffee in the stainless sink.. who has any ideas how to fix... the screws in both these are buggered and not able to get them out.. they come from quisinart that way.. buy another one? hmmmm i like them but.... getting to be a pain in the a..
  • 5 Answers
I found that a T-8 tool fits the screws perfectly. you have to have the wrench, the bits won't fit in the hole. If they are already buggered, a drill bit takes them out quickly. I'm looking for a heater element for mine, it seems hopeless. Cuisinart of course won't sell me one.
Posted on Jun 17, 2008
My truck builds air 4 or 5 times in a row on its own. Then all the sudden it stops and wont. If i put it in nutral and rev it up real high it will start building air again. What is causing this?
Sounds like your Unloader is hanging up. What type truck and year?
1 check air line to govenor make sure no leak.
2 Check dis-charge hose or pipe.
3 Check to make sure air drier pop off valve is not leaking
4 The unloader valve in compressors become gummed up and o-ring break and cause valve to hang up in open position which prevents it from building air.
Good luck
Jan 31, 2016 | Cars & Trucks
Water is leaking inside the fridge on the one side. Then fridge starts making a noise when closed. Stops when you opeb the door.
has your fridge got a water drain hole at the bottom/back? if so, it might be blocked.
Sep 08, 2014 | Refrigerators
I have a mazzer luigi coffee grinder on which set is the best coffee you get
grinding setting is one simple operation but requires a bit patience:
1 turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest ginding) 2 from that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line 3 grind little amount of coffee only to fill one sector of dosser than test it at your machine(if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way. 4 you test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation) 5 after setting measure the grinded coffee that come out from doser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of doser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Nov 14, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
Freezer bought in 1996. Moved to new address 3
what brand refrigerator is it? model number?
Mar 22, 2010 | Freezers
Automatic water dispenser not working/bypass valve leaking alot
Dear Rodeo mary,
Before you do anything else, please first defrost the fridge. Yes, turn it off and leave it open for a couple of hours until all the ice in all compartments has melted. Clean it and put it on again. Is it ok ? Please let me know.
arturocruz.
abwakhweya@yahoo.com
Jun 02, 2009 | KitchenAid KBRP20ERSS Stainless Steel...
A/c leaking can't find leak
UV dye?
Check especially the bearing area of the pump.
May 06, 2009 | 1999 Nissan Quest
Transmission is leaking toward the middle of the car
CHECK TO SEE IF YOUR TRANSMISSION PAN GASKET IS LEAKING/IF NOT CHECK ALL HOSES AND LINES/IF NOT REPLACE YOUR REAR MAIN SEAL.
Jan 06, 2009 | 2002 Buick Rendezvous
1999 Ford Escort idle problems
PVC valve is not metering air correctly, it will appear ok shaking it but looses it ability to maintain proper position causing a medium to gross vacuum leak.
Sep 12, 2008 | 1998 Ford Escort
1996 grand marquis fouling plugs fast
The upper intake gaskets leak on these engines, here is how to check this, get a can of carb spray, spray all around the engine top, esp around the upper intake/plenum gasket area, if the engine RPM changes you have a leak.
Aug 15, 2008 | 1996 Ford Crown Victoria
Cuisinart DCC-1200 Coffee Maker Logo
53 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
