I have a JVC Mod # av-56wp74 projection screen that when swithed on will pop and then the sound will burp for a minute or so. No picture will come up .
  • 19,396 Answers
Re: I have a JVC Mod # av-56wp74 projection screen that when swithed on will pop and then the sound will burp for a minute or so. No picture will come up .
Hi.
The pop sound is often given by a capacitor that is melting.
The part that most commonly fails causing this symptoms is the PSU board.
The PSU supplies power in different voltages to the different sections of TV. If fos some second there is sound, probably the DC lines going to ballast board to power up the lamp (or the CRTs-I do not have model info) is down because of PSU malfunction.
If the PSU is not faulty, next part to test would be the ballast board (s), that is also a power board.
Sometimes it is possible to find the sign of the fault at a glance, spotting a leaking or bulged capacitor or seeing the traces left by a short, but sometimes parts must be tested in full. Disconnect power first if you want to inspect the TV.
If you want to get a quote on repair call JVC. The customer support number is listed on manual and on their website.
Posted on Sep 01, 2010
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
No picture just clicking
I don't think I need to pay you so you can tell me that I need to have some one come in and repair this. It sounds like it neds a new relay and I don;t think you can fix this on line.
Sep 14, 2009 | JVC AV-56WP74 56" Rear Projection...
I have a JVC AV-56WP74 Rear Projection HDTV Ready Television...I had a problem with the convergence with dual pictures on screen...I replaced the convergence card with 110's.....This fixed the screen...
The STK392-110 are the stock ICs for your JVC. Chances are one or more of the feed resistors are bad. JVC TVs will usually have at least one bad resistor when the original ICs fail
Sep 06, 2009 | JVC AV-56WP74 56" Rear Projection...
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Feb 11, 2009 | JVC AV-56WP74 56" Rear Projection...
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc 56wp74
sounds like a solder related issue on the convergence ICs. They are acessed through the front of the TV behind the speaker grille and then remove the small acess panel and you will see the convergence amp board with the two ICs on it.
Oct 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
sounds like convergence amps bad
Oct 23, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
