Question about Dell Dimension™ E510 PC Desktop
On a dell e510 at start up i get to boot and then recieve the message....floppy diskette seeks failure....
    President:
  • 1,851 Answers
This means that your pc regognize a floppy disk in the drive, tried to boot from this floppy and the floppy is not bootable. You have 2 solutions:
  1. Remove the diskete from the floppy drive and restart. Assuming that your hard disk is ok the pc will boot normally.
  2. You have to enter the bios and change the boot order. Doing this you will change the boot priority and the pc will try to boot from the hard disk before the floppy drive. Since this solution it's more complicated from the first one, I suggest you to follow this way in case you are familiar with bios.
In case of a problem or clarification, or more details for the 2nd solution, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 01, 2010
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
Diskette Drive 0 Seek Failure This seems to be a
You are missing the OS.
If you have the restore CD's, use them to restore your Dell to original state, or you can order a set from Dell.
If you do not have a restore CD's you can also boot with a Windows CD and install the OS but you will have to go to the Dell website and download the drivers for your model.
I hope this helped.
Good luck and have a pleasent day.
Jun 20, 2011 | Dell Inspiron 530 Desktop Computer
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Alright i have a dell dimension E510 and i have no floppy disk. and it is saying that i have a floppy diskette seek failure . then at the bottom it also says alert! previous attempts at booting this system...
You will need to go into setup when you boot the computer and in that menu scroll down to the floppy disk and disable it. That should solve it. var fctb_tool=null; function FCTB_Init_c708739f53a84b7887b9dbecd89fa685(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_2800a0bea82c4f8db0c9352dc6041606(t) { fctb_tool=t; start(fctb_tool); }
Dec 26, 2010 | Computers & Internet
Receive message on startup: Floppy Diskette seek failure press F1 to continue
Just remove the diskette located in the floppy disk by pressing the appropriate button next to it. Reboot and check the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 05, 2010 | Dell Dimension E510 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension™ E510 PC Desktop Logo
157 people viewed this question
Alun Cox
