Question about Datalogic Gryphon GM4100 Linear Imager Barcode Scanner
I have a Gryphon GM4100 - When lifted from the cradle, It will scan one barcode then gives a low tone beep for every other attempted scan as though an error tone. I have been trying to reconfigure the settings but not sure I have done this correctly??
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
mrveder
  • 3 Answers
SOURCE: beeps instead of reading the barcode
Hi Richiet Seems liek it has not been detected into the system or has gone faulty. I would first wonder is ot a new item ? If so try reinstanning it on the system you are using, If it was an older item do the same but maybe look atthe fact that it could be faulty in both instances. YOu always have a warrenty with manufacture and by law they will have to give you full technical support on the item
Posted on Mar 09, 2007
SOURCE: Gryphon M100
Hmmm are these falling apart after 2 years? A customer of ours seems to be having that problem for about 1 or 2 months. Close to our date. I saw you are from America. We're located in Europe. I havn't seen it yet, but got told the red light / beam isn't rectangluar. Seems it more V shaped. Like at 1 end a piece is missing. A new pc installation didn't help. We still want more information before we drive there. So we know what to take with us. The clean the glass every now and then, so it should be clean. Wondering if it is the scanner if there is a led broken or some lose wiring or something. Then they probably need to buy a new one. IF someone knows any other tests to try or know the solution please let me know at niels@technico.nl
Posted on Aug 07, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
SOURCE: no data is transmitted
you need software to convert to barcode to text. im in the same boat right now...keep lookin ;)
Posted on Jul 22, 2008
How do I add a pause in the prefix of Barcode scanner GM4100?
I am not sure you can add a pause in the Prefix per se, but you can increase the Intercharacter delay which should achieve the result you want.
Download the Product Reference Guide for the GM4100 from this page: Gryphon GD4100
Here is the direct link to the 13MB PDF:
http://www.datalogic.com/tools/download.aspx?iddwnfile=1608&path=%2fupload%2fmarketlit%2fmanuals%2fgryphon%2f820050514.pdf&name=820050514
You will need to print several pages so that you can scan the appropriate codes to change the scanner setup. Follow the instructions on the following pages:
Pages 47 and 292 describes the Intercharacter Delay.
Pages 351 and 352 in Appendix D give you the number scans you will also need.
You might start with a 10ms delay and increase this until it works. A little experimentation will surely solve your problem.
Jan 28, 2015 | Datalogic Gryphon Computers & Internet
Gryphon GM4100
Which part of programming you required?Data Editing?Header/Terminator configuration?
Jul 14, 2014 | Datalogic Gryphon GM4100 Linear Imager...
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
HOW I WANT TO DISABLE ENTER AFTER I SCAN BARCODE..... I USE SCANNER MODEL GRYPHON GD4400
Just download print the GRYPHON quick reference guide (print on laser printer without zooming) and program the scanner to factory default.
Otherwise, you will need to download the FULL reference manual. Then print out the relevant programming barcodes that will remove the last character.
Dec 14, 2013 | Datalogic Gryphon Computers & Internet
]c1 : where to find the code to eliminate ]C1 when reading barcode EAN128 ?
Page 80, Section GS1-128 AIM ID Section of Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English)
Manuals
Aug 12, 2013 | Datalogic Gryphon I GM4100 Barcode Scanner...
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
When scanning green light goes on beeps and nothing else happens.
Here's a link to the page where you can download all the manuals, software, etc for that unit. You might need to cut and paste it into your browser's address bar. Godd luck!
http://www.scanning.datalogic.com/sitefiles/gryphonlgd4300.aspx
May 20, 2010 | Datalogic Gryphon L GD4300 Barcode Scanner...
3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Oct 05, 2009 | Symbol LS 4278 Barcode Scanner
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
Datalogic Gryphon GM4100 Linear Imager Barcode Scanner Logo
1,746 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
