Question about Brother MFC-8440 All-In-One Laser Printer
Printing problem for Brother MFC-8440
I have a very light uneven printing of any word document. If I print excel document it is find.
I have changed but cartridge and drum.
What is the problem?
  • 170 Answers
I dont believe this to be a printer hardware issue since you said it prints excel documents fine. If it were hardware related, it would genarally do the same thing to anything that is printed. I would advise you to download the latest and greatest driver for your printer.(make sure to download the correct one that jives with your operating system) I found this mirror site for your needed download if you need it... Click Here!
Posted on May 09, 2008
I have a mfc-8440, 5 years old, low usage, 50% drum life, new toner cartridge. The problem is that the contrast of the printed copy does not change regardless of the setting using the path...
This is very easy to solve. Remove the drum and toner cartridge. Look into the machine where they sat. Now look up and you will see (a little aukward but its there) a glass plate the width of an A4 sheet of paper. Run your finger accross it. Look at your finger and will probably be dirty. This is the window the laser beam passes thru to hit the drum. When its dirty it does not allow enough ;light to the drum hence a weak beam and light printing.
May 18, 2011 | Brother MFC-8440 All-In-One Laser Printer
Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
I have a Brother mfc-8440. It prints light on the
Usually when it prints light on one side and normal on the other, it's either the drum (which you replaced) a dirty corona wire, or the toner is unevenly distributed in the cartridge. You can removed the toner cartridge and gently drop it from a distance of about 4-5 inches to dislodge any caked up toner. This is normal in a cartridge that has sat a while or if the fax machine is in a room with high humidity.
Hope this answers your question and best of luck.
Aug 02, 2009 | Office Equipment & Supplies
Making a clanking noise when printing
Could be a fuser gear is broken or a Toner gear is about to break. Needs TLC by a Authorized Tech.
Feb 11, 2009 | Brother MFC8440 Remanufactured Laser...
Scan from brother MFC 8440 to pc
you need to make sure that the brother printer is et as the default printer
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 Automatic Feed Malfunction
you need to reset it from the printer setup menu
Nov 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 will not print or copy
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
menu * 2 8 6 4 super quick then 01, is full reset... warning all settings will be lost
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
192 people viewed this question
James Cagle
James Cagle
Jim Keysor
