Question about Epson TM-U220PD Matrix Printer
Cannot find the driver for Epson TM U220PD - Epson TM-U220PD Matrix Printer
  • 776 Answers
The drivers are avaialable onlingoing to the below mentioned link:
http://www.howtodrivers.com/model535852.html
http://www.bioticaindia.com/tm-u220pd.html
Posted on Sep 01, 2010
SOURCE:
Drivers epson tm-u220pd-603 for windows 7
Are you using OLE POS or you just need a regular windows 7 driver?
You need to register an account in epsonexpert.com, once your logged in follow this steps.
1. Go to technical resources.
2. Under printers look for the TM-U220 series.
3. Look for Windows Drivers, Advanced printer driver.
4. Select the up to date version which is 4.15 and click on the download icon (a paper with a red arrow pointing down).
5. There is some additional instructions found in the read me file just on the right part of the download icon. (The PDF icon).
Jun 03, 2011 | Epson TM-U220PD Matrix Printer
I need a printer driver for Epson TM-U220PD receipt printer for XP
http://www.posmicro.com/RECPRINTERS/EPSON/EPSON%20DRIVERS.htm here you go if it works let me know via a message or thumbs up if not i will continue to help you
Mar 16, 2011 | Epson TM-U220PD Matrix Printer
Trying to install epson tm u220pd with USB port, what drivers do I need? Plug and play does not install it in setup wizard
if your using TM-U220PD which is a parallel , you should connect it in parallel port then use this printer driver http://pos.epson.com/developers/techresdetails.htm?productpk=545
Feb 18, 2011 | Epson TM-U220 Matrix Printer
Where I can find driver of printer Epson TM U220PD for Windows7 ? ? ?
If there are any you'll get them here
https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?url_jsp=http://www.epson-pos.com/
Aug 19, 2010 | Epson TM-U220PD Matrix Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
TM-U220PD oN WINDOWS VISTA STARTER
Hi, you should try these drivers for Vista...has a preety nice install wizard (works on vista for me).
http://rapidshare.com/files/167170222/TM-http://rapidshare.com/files/167170222/TM-U220.zip.htmlU220.zip.html
good luck
Nov 17, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Jul 29, 2007 | Epson TM-U220PD Matrix Printer
Epson TM-U220PD Matrix Printer Logo
453 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
