Question about Refrigerators
It doesn't freeze and it's getting hot air now
  • 17,130 Answers
Possible that the compressor of the fridge is not pumping the gas with the right pressure.If the pumping is not good thenit must be overhauled or replaced but the estimated cost must be decided with the cost of a new fridge with warranty and bettter power efficiency.
Also the pressure of the gas inside must be also checked before the compressor can be confirmed.
Posted on Sep 01, 2010
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
On a 2001 saturn L series, 2.2 litre automatic. gas gauge doesn't work and the temp light blinks continuously while the temp gauge needle jumps continuously. i've checked the coolant levels,th
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 12, 2012 | 2001 Saturn L-Series
The heat in the car doesn't turn to hot air until
The antifreeze goes into the cooling system through the cap the same way you'd fill the system during normal car maintenance. You may have another issue as well. There is usually a vacuum or electrically operated shut off valve in line in the heater hoses. Its typically located on the passenger's side close to the firewall under the hood. Its purpose is to keep hot antifreeze from flowing into the heater core when the air conditioning is on. If this valve, a temp sending unit that works in conjunction with this valve or the climate control or a break in the electrical circuit or vacuum line or valve isn't working properly, the symptoms that you describe could and likely would arise. You can usually move this valve open or closed manually to test. Check and repair or replace accordingly if low antifreeze doesn't rectify the problem. Good luck!
Jan 17, 2012 | 2003 Mercury Grand Marquis
1999 Chrysler 300m heater won't get hot fan blows but doesn't heat
Is there enough anti-freeze in the system?
If so perhaps the system needs bleeding.
On the front of the engine, on top near the big upper hose goose neck and nestled between the runners of the intake manifold is a small nipple that looks like a brake bleeder (10MM). This is a cooling system bleeder, a close cousin to the brake bleeder. When opened it will purge the system of air- likely the culpret you are experiencing. on a cold or just warm engine, this can be slightly opened with a wrench and the air can be "Burped" out. Attach a 1/4" clear hose to the nipple and open the bleeder until you see all the air has left the manifold. (Run the hose into a bucket and dispose of the used anti-freeze properly.)
if that doesn't do it, maybe the thermostat is stuck in the open position. Replace it with a cold engine and use a new gasket each time.
If all else fails, the heater core may be plugged.
Nov 07, 2011 | 1999 Chrysler 300M
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
Freezer will not freez ,warm air
replace temp sensor, should work also first check drain pipe some time gets blocked.same symptoms...
Feb 07, 2010 | Refrigerators
Plenty of air but no heat one side of dash use to blow hot air. Now neither side blows hot air. 2000 jeep grand cherokee coolant is fine driver side seat heater doesn"t work air bag light comes on every...
Check to see that the blend door linkage is hooked up. Doubtful it is heater core, as you had heat to one side and not the other. Check coolant control valve linkage, verify it is moving the coolant valve from off to on when you switch temperature from cold to hot. Verify you have coolant flow to the heater core by feeling the heater hoses where they enter the firewall. If all checks out well, then look at hvac controls individually.
Jan 06, 2010 | 2000 Jeep Grand Cherokee
Temperature gauge fluctuates and the heater blows cold air
Definitely check your fluid level in your radiator. Top it off all the way. I've seen that happen multiple times on cars that were low on anti-freeze. If that doesn't work try replacing your thermostat. It's cheap and the easiest place to start if topping off the fluid doesn't get you fixed up.
Oct 16, 2009 | 1997 Chevrolet Camaro
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
