Paper is not getting printed and it is getting stuck.
  • 1,218 Answers
The paper used for printing should not be wet, torn or folded from any side as this can cause paper jam, hence resulting in carriage jam. Also, use only one type of paper at a time while printing. The paper should be added to the In-tray only when the printer is not in use. Make sure not to overfill the In-tray. get more information and help for paper jam problems .
Posted on Sep 01, 2010
HP 2200LaserJet prints a few pages, then gets stuck
You may have a recurrent paper jam. Use a strong light to examine the entire paper path. Even a tiny fragment of paper can cause the problem you describe
Jan 27, 2013 | HP LaserJet 2200D Printer
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
Paper stuck under the print head container
pls clean ur drum with tissue paper or soft cloth and then try once
even after if the same thing happens change the drum or catridge
Sep 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Regular paper jams and printed images are not straight
hi,
follow these steps:-
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
mannu_rakesh
Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper keeps getting stuck
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Paper stuck while printing on lexmark X5470
You might have a little paper stuck inside your printer or just clean the pick-up roller with alcool and try it again.
Mar 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
k24674
