Question about Gigabyte GA-8KNXP Motherboard
Harddrive wanting to use a ide harddrive instead of sata but not sure which ide slot to use
    Master:
  • 441 Answers
ON the mobo, there is a slot there for the IDE cable usually its yellow, and its the only slot where the IDE cable can fit, the other slot there is for FDD(floppy).After you connect the cacble the the IDE HDD, go to your bios and check if you can detect it.
Posted on May 09, 2008
Skimatice for hard drive connections
Schematic
The eMachines T6532 uses an MSI MS-7207 motherboard.
Also known as the KN8GM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
[ http://www.newegg.com/product/product.aspx?Item=N82E16813130041 ]
The MSI motherboard has provisions for using, EITHER an
IDE (PATA) harddrive, or a SATA harddrive. (Or more than one)
Two different technologies.
I will explain both, using an IDE (PATA) harddrive,
OR;
Using a SATA harddrive;
On the MSI Support page above, click on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Language > English > 7.1MB > E7207v2.0.zip
Click on the blue E7207v2.0.zip
On the next page click on the country name nearest yours.
A small window will come up -
Opening E7207v2.0.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; Left-click in the small circle to the left of Save File.
Now go below in the small window, and click on OK
A small download window will come up. Allow the file to download ALL the way, then DOUBLE-click right on it.
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(7207v2.0(G52-M7207X5) next to the red Adobe PDF icon)
There is the Motherboard Manual
The MS-7207 has two IDE slots;
IDE 1, which is Yellow in color, and close to the outside edge of the motherboard.
Should have IDE 1 silkscreened on the motherboard, below it.
IDE 2 is Yellow in color also, and right next to IDE 1.
(IDE 2 is in-between IDE 1 and the Ram Memory slots.
The Purple, Slot 4, ram memory slot to be specific. {DIMM 4 )
IDE 1 is used for an IDE harddrive.
IDE 2 is used for an IDE optical drive.
TWO IDE harddrives can be put on a single flat ribbon IDE cable,
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
NOTE that there are two styles of IDE flat ribbon cables;
40-wire cable,
OR;
80-wire cable.
BOTH have 40 socket holes in their connectors.
(ONLY 39 are used, so one hole May, or May Not be blocked off)
How to connect to a 40-wire IDE cable, or an 80-wire IDE cable,
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
An IDE cable usually has a Locating Lug on it's connectors, in the middle of the connector; and on one side,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Here you see the Locating Lug as being two separate 'ridges'.
Some styles the Locating Lug is single block.
The motherboard connector has a matching Cutout on one side.
The Locating Lug lines up with the cutout when installing the cable.
The Harddrive, and optical drive (CD/DVD drive), will have a cutout on their circuit boards.
There are 40-pins. (Only 39 are used if so)
One of them is the number 1 pin.
The IDE cables are plugged into the motherboard, with number 1 pin lining up with number 1 wire, in the IDE cable.
Same when the IDE cable is plugged into a Harddrive, or optical drive.
IF, there is no Locating Lug on the IDE cable;
Look for the faint RED stripe, on the side of the IDE cable.
Number 1 wire is on the same side, as the faint Red stripe.
When plugging into a motherboard, Number 1 pin is on the Bottom.
The faint red stripe on the cable, goes towards the BOTTOM of the motherboard.
(Motherboard installed in computer case)
When plugging into a Harddrive, or optical drive; the faint red stripe ALWAYS goes toward the power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
This shows you the Back of an IDE (PATA) harddrive, and the power cable used for it.
If -> No Locating Lug on IDE cable, the faint Red stripe goes towards the power cable.
This is a 4-pin standard Peripheral power cable.
Note when installing the rounded corners ALWAYS goes UP.
[This power cable is frequently, and erroneously; referred to as a 'Molex' power cable.
Molex was just the first manufacturer of the power cable CONNECTOR. Name STUCK.
Kind of like calling an adjustable open-end wrench, a 'Crescent wrench ]
A SATA power cable is used for a SATA harddrive, or SATA optical drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
There is an L-shape in the SATA power cable's connector.
It matches an L-shape on the Harddrive, or optical drive.
Between a SATA power cable's connector, and a SATA data cable's connector; a SATA power cable connector is the LARGER of the two.
A SATA power cable has 15-contact pins.
A SATA data cable has 7-contact pins.
A SATA power cable's connector may have a LOCK on it.
Usually a Tab, or 'bulb' type affair.
It is pressed down with the thumb when installing, or removing the SATA power cable.
This is a general example of a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
Now you can see the L-shaped opening a little better, that both the SATA data cable have, and the SATA power cable, has.
In the photo the SATA data cable's connector, is a 90 degree bent Elbow.
This style of connector is usually used on the Harddrive, or on the optical drive.
A Straight connector style is usually used for the Motherboard.
However, you can use a SATA data cable, that has a Straight connector on both ends.
Looking at your motherboard, installed in a computer case; there are 2 SATA connectors on the motherboard.
(CAN, be up to FOUR)
I see one motherboard reference where they (2) are Orange in color, (Newegg), and the motherboard manual shows them (2) to be Purple in color.
They are located towards the Bottom/Right corner of the motherboard.
Above the CMOS battery.
The SATA connector that is closest to the Outside edge of the motherboard, is SATA1 (SATA 1)
The Harddrive plugs into SATA 1.
An optical drive that is SATA, will plug into the SATA2 connector.
To the Left of the SATA1 connector.
KNOW THIS;
DOES NOT MATTER, which SATA connector you plug the Harddrive, or optical drive; into.
The beauty of SATA, is that you can plug the Harddrive or optical drive into ANY SATA connector, (On ANY motherboard), and BIOS will find those devices.
BIOS looks FIRST, to see which drive has the Operating System on it. (Windows)
THAT, is the Harddrive.
After finding the drive with the O/S on it, then BIOS will find all the other drives. Removable, or not.
So there you have it. A lot of reading.
You need a power cable, and a data cable to the Harddrive.
Same thing for the optical drive/s.
To have me clarify anything I have stated above, please post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 15, 2013 | E-Machines T6532 PC Desktop
Gateway gt4016 motherboard
It has Parallel ATA
PATA or also generally known as IDE,
http://en.wikipedia.org/wiki/Parallel_ATA
1) Harddrive:
101311 - Western Digital, 200-GB, 7200RPM, PATA harddrive,
http://support.gateway.com/s/PC/R/1008842/1008842cl2.shtml
2) Motherboard:
105553 FIC KTBC51G
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtml
Product Views; F - Primary IDE Connector,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr7.shtml
Left side of motherboard, near the black long Ram Memory slots.
This is where the Harddrive plugs in.
Product Views; E - Secondary IDE Connector;
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr6.shtml
Near the black long Ram Memory slots, and next to the blue Primary IDE Connector.
This is Serial ATA, or also known as SATA,
http://en.wikipedia.org/wiki/Serial_ATA
Uses this style of SATA data cable, and connector on motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(NOTE* Color does NOT matter for cable connector.
Color really doesn't matter, for a SATA connector on the motherboard, either.
You are supposed to plug the Primary SATA harddrive, into the SATA 1 connector, on the motherboard.
The beauty of SATA is, that you can plug into any Ol' SATA connector on the motherboard, that you want to.
BIOS will find the harddrive with the Operating System on it, and will find all the other SATA devices plugged into the motherboard, too )
You do NOT have SATA.
Regards,
joecoolvette
[You may be interested in this,
What's Inside: Computer > Computer Hardware > Explore These Categories,
http://computer.howstuffworks.com/
Also to the left;
Computer Peripherals
Computer Security
Computer Software
Internet
And,
http://www.hardwaresecrets.com/
Click on the headings at the top;
Case, (Computer cases), Cooling, CPU, (Processor), Input, Memory, etc.
Has basic information leading up to technical ]
Nov 30, 2012 | Computers & Internet
Will xw4300 accept compaq S6200cl hard drive
HP XW4300 Workstation Desktop PC specs,
http://h18000.www1.hp.com/products/quickspecs/12260_na/12260_na.HTML
Scroll down to you come to the bold heading -
Standard Features - Specs
Go down the chart on the left side until you come to -
Interfaces Supported
1 SATA 3Gb/s interface (4 Serial-ATA connectors), 1 EIDE interface for optical drives
One EIDE interface. That is the Blue 40-pin connector, on the right side of the Ram Memory slots. (39-pin actually)
(Right next to the Black Floppy Drive 34-pin connector, and above the 4 SATA connectors)
Compaq Presario S6200cl Desktop PC >Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=390423
Product Information > Product Specifications > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00056951&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=390423
Scroll down to the bold heading -
Hard drive
120GB Ultra DMA
It is an EIDE harddrive.
HP XW4300 Workstation motherboard example,
http://www.ebay.com/itm/HP-XW4200-XW620-DDR2-MOTHERBOARD-358701-001-SOCKET-775-/110904128317?pt=Motherboards&hash=item19d266b33d
The answer is Yes.
Connect just the EIDE harddrive from the Compaq.
Make sure the correct jumper pins on the back of the harddrive, have a jumper cap on them to set them to Single;
OR,
The IDE harddrive model you have may Not use a jumper cap on any jumper pins, for some models of harddrives, to set the harddrive as Single.
Look up the harddrive jumper settings on the internet.
Start with the model number on the label of the harddrive.
Example; WD2500JB
Western Digital 250GB harddrive that is IDE. (EIDE)
Western Digital jumper settings for IDE (EIDE) harddrives,
http://wdc.custhelp.com/app/answers/detail/a_id/463/c/123/session/L3RpbWUvMTM1MjE4NDY3Ni9zaWQvQnoxcVF6YWw%3D
You will need a SATA optical drive now.
BIOS Setup > Boot Options > Set the first boot device to CDROM.
Install Windows disk.
Use IDE harddrive, and IDE optical drive on the same flat ribbon IDE cable?
Can be done, but usually is a HEADACHE, and MAY not work.
BIOS looks to see what drives are connected. It looks for the drive with the Operating System on it. (Windows)
Now put a disk in the optical drive. Time has to be divided between the harddrive, and the optical drive.
IF it does work; when you are using the computer, and the optical drive you will know the real meaning of Slow.
Have a SATA optical drive?
Regards,
joecoolvette
Nov 05, 2012 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Hi, I have destop[ dell pentium R 4 cpu 3 GHz 1.99 GB of ram and 40 GB rom . I want to now if can change the hard disk and put another of 160 GB. tanks you carlos.
A) If you have the Restoration Disk (CD), or a full installation disk of the Windows operating system, the answer is yes.
B) If you have an image backup program, such as Norton Ghost, Acronis True Image, or DriveImage XML, for example, the answer is yes.
The Windows operating system is copied over to the new harddrive.
It would be easier, and more cost effective to just install the 160GB harddrive as a Slave drive.
I don't know if your harddrive is an IDE (PATA) unit, or a SATA unit.
Here is more information on installing either an IDE harddrive, or a SATA harddrive, as a Slave drive in a desktop computer,
1) IDE {PATA} harddrive:
http://www.youtube.com/watch?v=4inX3nC6M1E
1A) http://www.youtube.com/watch?v=OMTOgt3UiB4
2) SATA harddrive:
http://www.youtube.com/watch?v=kCgFYNLzn18&NR=1
IDE, also known as PATA is the older style of technology.
SATA is the newer style.
(Parallel ATA
Serial ATA )
The beauty of SATA is not only the faster speed, but if you connect a SATA cable (Data cable) to ANY SATA connector on the motherboard, BIOS will find the device.
BIOS (Basic Input/Output System) will find the harddrive with the operating system on it, first.
Then it will recognize that you have a second SATA harddrive also.
(BIOS looks at both SATA harddrives.
When it finds the one with the operating system on it, BIOS will disregard the other SATA harddrive)
http://www.youtube.com/watch?v=ScqDZZeFK9I
Regards,
joecoolvette
Jul 17, 2011 | Dell Computers & Internet
I have a samsung hmo 6011 harddrive can i replace it with a samsung f3 sata 11 drive
If the samsung hmo 6011 harddrive (couldn't find that model) is SATA then yes, and SATA drive will work. The only thing to make sure is that you get the right size; for a laptop or PC. If the samsung hmo 6011 harddrive is IDE (has pins) then no, they cannot directly replace with a SATA.
Here is a good comparison picture http://www.laptopparts101.com/wp-content/uploads/2008/12/sata-ide-laptop-hard-drive.jpg
Feb 03, 2010 | Computers & Internet
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Installing a new harddrive
Uses a SATA cable. If you're using an IDE harddrive that uses a 40 pin connector, there are IDE to SATA adaptors available.
The power connector is also different on SATA Harddrives.
Jun 18, 2008 | Dell Dimension XPS 400 PC Desktop
Connection of two harddisk
One ide channel can have two devices, most pcs have two ide channels primary and secondary.
if You have 2 ide channels then you can install total of 4 ide drives into your pc.
if you have only one ide channel / connector on your motherboard then you can install only 2 ide drives into your pc.
your pc might also have sata slots for devices.
1 drive / connector.
Installing a drive is very simple.
open the pc case.
Locate a free ide cable, connect your harddrive to it and also attach the power cable. Thats it.
May 08, 2008 | Intel Motherboard
Connectind to SATA slots
you must get an IDE to SATA converter as below
Dec 17, 2007 | Intel Motherboard
Gigabyte GA-8KNXP Motherboard Logo
74 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
