Kenmore washer top load no spin
I have a Kenmore washer top load Model 20904. First stopped spinning then agitating. Makes some grinding noise when I try to restart it. Drains water OK. I suspected a coupling problem but could be something else. I removed the console and the cabinet then unscrewed all 3 retaining motor screws. The motor doesn't go down, seems to be retained by some part; by the anti-rattle clip as shown in the manual? I can't inspect the couplings if I can't remove the motor, unless something else is wrong.
Many thanks in anticipation for help.
  • mishu64 May 10, 2008
    Fixed by myself.
    Didn't have time to wait. I turned the machine upside down, removed the pump, then pulled the motor away from the gear case and there it was: a broken coupling. Made from plastic and rubber. Some plastics are aging fast and it's normal to be in the first line of failures. The exploded illustrations in the manual were more than helpful.
    Sounds easy but this job is no fun.
  • 117 Answers
That is only 2 screws holding the motor, and 2 clips at the pump a 2 at the motor.
1st took the pump and than the motor and you gonna see the coupling
Posted on May 10, 2008
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Broken Washer
sounds like you have a broken drive coupling....will the unit agitate ok??
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
