Question about Furuno 1942 Mk2 Radar
Dear Sir/Madam. I have a Furuno 1942/Mark2 radar on which the heading marker is way off dead ahead (in fact showing about(in fact about 15° off to port). How can I adjust this? Is the adjustment via the display menus (I am unable to enter the 'installation setup' menu), or do I have to look at the scanner unit? Many thanks
  • 944 Answers
You have to reset the Furuno to factory settings this will solve your problem.
The reset procedure is clearly available in the manual.The master reset will reset all the settings.
scanner unit is not having any problem.
Since you say you are not able to enter menu.There is some corruption in the firmware.
If you are not able to pass through menu,then you should call Furuno service center they would give you some set of keys to be pressed for each model it differs so the system gets to old factory settings and now you can configure it correctly.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
Tip
Furuno VX2 Radar heading alignment
Please take the time to rate this tip!
This tip applies to all VX2 radars from Furuno. Models Include 1724c, 1734c, 1824c, 1834c, 1934c, 1944c, 1954c, 1964c, 1724cnt, 17234cnt, 1824cnt, 1834cnt, 1934cnt, 1944cnt, 1954cnt, 1964cnt, and 19XXBB series black box radar processors.When the picture is "crooked", "rotated" or "needs re aiming" you need to do the radar heading alignment. In order to do the radar heading aligment, you must access the installation menus, available only in installation setup mode.
Press and hold "MENU" during power on.Continue holding menu during start up, at least until the boat appears.
Choose , "Installation Mode", Choose "Menu", "System Configuration", "Installation Set Up" "Radar Set Up".
Here is where people get lost! Choose "Next Page", Choose "Heading Alignment". You will be prompted to place the dotted line on a target "dead ahead". Follow instructions and then, do not forget to press "SET". Press Return Return Return or Menu to exit and resume normal operation.
Note that the installation menus disappear if they are not accessed for five minutes!.
Please take the time to rate this tip.
That is all there is to it.
Please "Optimize Radar Video" in same menu (Radar Set Up).
847-746-0100
www.technicalmarine.com
on Jan 17, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno MK 1942. The antenna does not spin. There is a message on the screen "HDG SIG MISSING". Though the magnetron is fairly new one. I can´t access the Instalation Setup at MENU > OTHER...
Either you have a bad cable, or the motor has given up. Sometimes it can be the mod. board but the bearing pulse generator is located on the motor itself. Also check to see if theres a switch on the back.
Oct 14, 2010 | Furuno 1942 Mk2 Radar
1942 mark2 has power to display but no rotation on screen. Head unit turns.unit has worked for years and all of the sudden quit.check fuse and is ok
To be check the Fuses:1)for antenna ,2)for modulator unit
that are from 4amps until 7amps slow blow
rgrds
Grigorios
May 19, 2010 | Furuno 1942 Mk2 Radar
I have a apelco m88307 radar dome, can this unit be used with other type or brand screens?
do you still have this radar dome? i am looking to replace the one I just busted as I didnt have enough clearance on the barn door. my email is david.d.connell@gmail.com
Mar 10, 2010 | Furuno 1942 Mk2 Radar
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
Furuno 1942 MK2 : The radar don't show any echos on the screen.
The gain truned up and filling the screen with dots tells me the M.I.C. is Ok. Since you array fills with water, there is a very very good chance that the wave guide has given up. A good tell tale sign is that there is white powder laying on rectangular aperture located in the center when you raise the lid on the chassis. A new Array will probably be needed and that will cost you anywhere from $800.00 to 1200.00 just for the part. The water is probably getting in from the array from a bad install as well. normally the chasiss does not leak unless you did something wrong.
Oct 22, 2009 | Furuno 1942 Mk2 Radar
Hello there, I have a 4' radar antena with a
ahh, this is an old one check the book.(ha, ha)
Press and hold menu during start up Choose "Installation Mode" Press "Menu" Select "Radar Set Up" Press "Next Page" Select "Radar Heading Alignment" Use knob and follow prompts, you will place the dotted line at dead ahaed and the
Select "Set"
Also, remember to TUNE VIDEO
Oct 08, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Hi, I have a Radar Screen. Furuno 1942 MK2 . What Radar Dome can i plug this into. I have a Furuno 1720 Dome
A 1942 is a 6 kw radar a 1720 is either a 1.5 or 2.2 kw dome. The two will not work together. Besides the cabling is different. Also the radar cable on a 1942 is round where as the 1720 is square. The 1942 display should work fine on a 1943 navnet radar.
Sep 24, 2009 | Furuno 1942 Mk2 Radar
Furuno Radar Model 1833C
You have two things that orient the radar, on is called heading (or bearing) alignment. This is where you aim your radar so that a target comes up at 12 o'clock when dead ahead. Access this mode by pressing and holding menu duing power on, and go in to Installation Mode, radar setup, next page, align heading. I have posted a "tip" on this, search for VX2 radar alignment.
After this is done, North up is accomplished by having a magnetic input (fluxgate compass or autopilot). Calibration of this compass varies, but if it is accurate, then all should line up nicely.
Jul 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno 1942 Mk2 Radar Logo
82 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
