Question about LG Electronics LRM-519 Digital Media Recorder
Lrm-519 Had a power outage the other night. Now the LRM-519 just stays at the Hello prompt. Looked inside and saw a steady green light and a flashing red light. Any assistance would be appreciated.
  • ppatel5 Jun 23, 2008
    Could you please explain the fix as I have the same problem. It just says hello. I did reset and cold boot and also soft boot but nothing else then Hello. Please help!!!
  • jbmcsorley Sep 22, 2008
    I'm hoping someone knows how to solve this problem because it is happening to me too. After holding down the power button for 5 seconds to force a restart, something inside clicks a few times and then nothing. Display simply reads "Hello" with no screen or boot activity at all. Did the hard drive crash?
  • 80 Answers
Change c18 and c36 both are 2200uf at 10v - they are on the power supply and most of the time they are green
Posted on Jun 12, 2008
I have a power problem with my LG setop. I had it reparied by LG service center once, but it failed again. As it is not in warranty LG said they will charge me for repair. Is there any way I can fix the problem on my own. The problem is NO POWER to the system. I tried different outlets and also different cables. Seems like a problem with system itself.
Posted on Oct 13, 2008
I was about to throw away my DVR... I had tried about everything proposed on this site, except replacing C18 and C36. It did work! Note that the display is still quite dim, but replacing C18 and C36 did work, thanks to nipper00 post!
Posted on Sep 27, 2008
I have two lg lrm-519 dvr's both power supply's went out about 4 months apart where can i get this fixed?
I have repaired two different LRM-519 that both had the same problem. The repair was a simple replacement of two capacitors on of the power supply board of each unit. You can search the web for repair instructions, or even search youtube for a video of the repair.
If you have the same problem I had then when you turn on your recorder it will only display the Hello message on the front of the unit (perhaps very dim) and the blue light on the power button will come on. Your next step is to open the device (about 7 screws) and slide the top off, then examine the tops of the capacitors on the power supply, if the tops of one or more are bulging up then this is a good candidate for attempting this repair.
For parts I found some on ebay and searching the web. If you don't want to do the repair yourself I have also seen people offer the power supply repair on ebay.
Jul 06, 2010 | LG Electronics LRM-519 Digital Media...
I have a LG LRM 519 and the power supply went out and the component is located at U1 with no part # on the component can you help?
Hello, the component that got faulty identify as U1 is a regulator and this is a 19V regulator as written on the number . do replace for a new one or an equivalent
May 19, 2010 | LG Electronics LRM-519 Digital Media...
Lg lrm-519 went into demo mode. Can't get it back
follow directions from the owners manual. while unit is powered up, unplug power cord from back of unit - wait 5-seconds. Depress the DVD open/close button while re-plugging the power supply cord to the unit. LG splash appears onscreen and unit goes into re-set. you do not loose any of you programing or settings.
Jul 18, 2009 | LG Electronics LRM-519 Digital Media...
LG LRM 519 Parts no longer available
See this thread:
http://www.fixya.com/support/t1426431-lrm_519_replace_capacitors
I have ordered the two new capacitors that should fix the problem.
Mar 27, 2009 | LG Electronics LRM-519 Digital Media...
LG LRM-519 When turns on, hello appears and that's as far as it will go. Any asst. would be great. Thanks.
Sounds like a software error while the dvd is booting up. Did you try unpluging the unit for a while and pluging it back in?
Jan 24, 2009 | LG Electronics LRM-519 Digital Media...
LG media recorder LRM-519 locked up.
REPLACE C18&C36 0N THE POWER SUPPLY BOARD AND GET BACK TO ENJOYING YOUR UNIT!!
Jan 19, 2009 | LG Electronics LRM-519 Digital Media...
Installation of LG LRM DVD Recorder Model 519
be more specific with the problems you're having. following the instructions should be straight-forward. if you are using composite cables from the unit to your tv, be sure the composite/480i/480p switch is et to "composite". it'sa small black switch on the back of the unit. make your selection while the unit is powere off. Finally, the composit cables are usually plugged in to the "AV" inputs on the TV -- make sure you set your TV's input to "AV"
Oct 02, 2008 | LG Electronics LRM-519 Digital Media...
LG LRM-519
There is a good chance that the capacitors detailed in this video need to be replaced:
May 21, 2008 | LG Electronics LRM-519 Digital Media...
LG LRM-519 Not responding to anythiing
I had a LRM-519 that would not get past a very dimly lit "hello" on the LED screen. I called tech support and was advised to make sure no disk was in the unit and turn off the power from the unit (not the remote) and unplug it from the wall outlet. While unplugged, hold down the power button for 30 seconds then plug it back in. This didn't work the first time, but after a few tries it worked for me. My unit hadn't worked for nearly 3 months prior to this. Good luck.
Mar 31, 2008 | LG Electronics LRM-519 Digital Media...
Lrm 519
Had same problem. My fix was to repair power supply.
On power supply board replace capictors C18 & C36.
2200mf 10v rated 105C
Dec 25, 2007 | LG Electronics LRM-519 Digital Media...
LG Electronics LRM-519 Digital Media Recorder Logo
408 people viewed this question
Computer Repairing
Computer Repairing
