Question about Acer AL1703 17" LCD Monitor
My Acer LCD monitor AL1702W showing very bright colors it is got whiteish i can't able to see proper i have tried to adjust contrast & brightness but problem is not solved yet,so pls help me as i want to know the solution & if it service provider is required then give me the contact details as my lcd is under warranty.
bostonbiker
  • 3 Answers
SOURCE: Acer 19 " LCD Computer monitor
By initiating the on screen menu, you navigate to the brihghtness etc.This can also be related to contrast. Get a keyboard with zoom keys that will make it east to enlarge text.Mine is a logitech wireless S510 and its a great bargain and comes with mouse.the best solution is, however to buy a 42 inch or larger display and use that as you monitor. I can never go back!
Posted on Dec 05, 2007
scottyfixit
  • 186 Answers
SOURCE: brightness/contrast
Sometimes all you have to do is press the left or right adjustment buttons, one will bring up contrast adjustment, the other brightness.
 Otherwise simply browse through the menu settings.
Posted on Apr 23, 2008
SOURCE: Dell 15 inch monitor, brightness/contrast window
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
  • 14 Answers
SOURCE: Hello how to adjust brightness on an ACER 19
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
Posted on Apr 01, 2009
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Acermointors color is to bright
try to adjust front panel button, for the brightness control + - sign, if not function the problem is the lcd ckt. and need service.
Mar 25, 2010 | Acer 22" X223w LCD Monitor
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
Contrast on my acer monitor is bad how do you adjust it
You can use the monitor's own settings, but that doesn't work very well. I just bought an Acer V233H monitor myself, and I am very disappointed about the quality of contrast and color.
However, I have NVIDIA video card, which comes with software that you can use to adjust gamma, colors, contrast etc. That worked better for me. Still not perfect, but better than the monitor's own settings.
Oct 15, 2009 | Acer 19" LCD Monitor
LCD is way to bright to see. No contrast. Works
Try to see your power managments for setup. If you cannot, see the advance on Display > setting> advance> to see your graphic cards adjustment. (Color Managment)
Goodluck
JMC
Aug 18, 2009 | Acer Aspire 5570-2067 Notebook
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1703 17" LCD Monitor Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
