Question about Gateway Computers & Internet
WAS MISSING CHARGER, but was running on battery. will not charge battery or power up, no lights. Battery went dead MT6821 GATEWAY
  • 776 Answers
All you need to do is be sure whu will need to replace both.
If the problem is with either the charger/battery you will need to figure that out first.
Please have the battery charged of your laptop, and try using the laptop only with the battery and without the charger, If it works fine you will have to check the charger now.
In order to check the charger, please take out the battery from the laptop, now connect your charger to the laptop and try switching on the laptop. If it does not work then your charger is faulty.
You can purchase the accessories online at various portals. I am providing one of the portal information:
http://www.laptoptraveller.com/battery-gateway-mt6821-laptop-notebook-accessories.html
Posted on Sep 01, 2010
Gateway NV52 Battery LED blinks 5 times then nothing. Will not start/boot Power LED does not come on. Know battery charger is bad but battery shows 10v charge. Where do I look next?
Power adapter faults will often take out components on the motherboard as well, including the processor.
Google
gateway blink codes.
You aren't the first to have this problem!
Google
Nov 08, 2016 | Gateway Computers & Internet
Battery just changed, but then went dead. Battery Tender blinks red.
Its possible the charger is telling you the battery is too dead for the charger to work. A safety feature to keep from burning up the charger.
I'm not aware of any fuses between the jumping post and the battery. You may have a short in the car that is draining power.
Mar 05, 2014 | Chrysler Sebring Cars & Trucks
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
I PRESS POWER AND A RED LIGHT FLASHERS 4 TIMES
I believe the problem you are experiencing may be due to a dead battery. I'm not saying in the sense that it needs to be charged, but that it won't hold a charge. Try replacing the battery in your Notebook with another, but save the receipt. If it still doesn't work then you likely have a failure with a piece of hardware inside the notebook and it needs to be serviced.
This isn't software related and I wouldn't recommend opening the Notebook yourself unless you really know what you're doing. One wrong thing in there and you won't only void the warranty, you could also cause permanent damage to multiple system components.
Jan 04, 2011 | Gateway MT6821 Notebook
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Gateway MT6821 doesn't charge; I already exchanged the external power supply, and it still won't charge.
the battery is damaged and has to be replaced, take the battery out and should be able to use it on AC power until you get a replacement
regards
Nov 24, 2008 | Computers & Internet
Stopped turning on, charge light appears when plugged in...
try removing the battery and plug in AC power only and power up, sounds like you may have shorted the battery
regards
Nov 24, 2008 | Gateway CX2610 Notebook
My gateway mt6839b wont turn on anymore
Gateway was working good went upstairs came back NOTHING BLACK SCREEN....
My gateway screen was constently black every time I powered on nothing no bios, nostart up no warning..The board has indicating lights to follow the start up power light on, battery light on, then the disk drive....but thats it normaly the harddrive reader light comes on but nothing.... So detached every component and tested individually..... come to find out one of my 2 ram slots is damaged not the chips...this could be your problem..try
Skillz Unlimited MDA
Nov 20, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
177 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
