Question about Dell Latitude D430 Notebook
How do i disable the touchpad on the dell d430 when the mouse is connected?
  • 776 Answers
All you need to do is go into control panel, open up MOUSE and click on TOUCH PAD SETTINGS then DEVICE SELECT and then DISABLE TOUCHPAD.
Posted on Sep 01, 2010
  • 61 Answers
Search through control panel you get the link to it
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached.
May 06, 2017 | Dell Vostro 1510 Laptop
How to disable my touchpad on Dell Inspiron M5030 (only) when my Logitech external mouse is connected? Thanks.
You can find some instructions on disabling the touchpad herehttp://www.labnol.org/software/disable-touchpad-on-laptop/14052/
and this link has a piece of freeware called TouchPad Pal which allows you to disable the touchpad while you're typing (which should be the only time it gets in the way really) http://download.cnet.com/TouchpadPal/3000-2084_4-11143760.html
Hope this helps!
May 19, 2011 | Dell Inspiron M5030 Laptop
Want to disable the touchpad. When I type i accidenlty hit it and it makes the cursor move.
First, make sure the device drivers for the touchpad are installed.
Once the drivers are installed, open Control Panel --> Mouse --> Dell Touchpad.
Click on the large screen with an arrow, which will open the touchpad configuration window.
Click on 'Device Select', and right at the bottom is a box which you can tick to 'Disable Touchpad/Pointing Stick when a USB mouse is connected.
As soon as you tick that option, a message will pop up in the taskbar, confirming your selection.
You can make doubly sure however, by also choosing 'Disable' under the Touchpad' heading in the same window.
Be sure to click 'Apply' once you've made your selections.
Mar 06, 2011 | Dell Latitude E5400 Laptop
My dell latitude d430 touchpad is not working at all
To fix your touchpad, follow the information from this link.
Jan 07, 2011 | Dell Latitude D430 Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Dec 11, 2008 | Computers & Internet
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Aug 28, 2008 | Computers & Internet
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Jul 10, 2008 | Dell F3534 Touchpad
Dell Latitude D430 Notebook Logo
652 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
