Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears. Have turned off on. Removed power source. Taken cartridges out and put back in - no luck.
    Genius:
  • 1,087 Answers
Nice job on trying different ways to resolve the problem - turning off/on the printer, removing power source, reseating the cartridges and even changing the cartridge with a genuine Lexmark cartridge. You pretty much did the necessary. Genuine Lexmark cartridges shouldn't cause you that much trouble. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Posted on Sep 01, 2010
Stopped printing needs black toner
I guess that you does not use a genuin cartridge
Mar 15, 2010 | HP LaserJet 2820 Printer
I have an Epson TX100, and still using original ink cartidges, of which there are 4. The black ran out, so I replaced with an ESSE branch Epson No. 73. The message came up that the cartridge was...
What worked for me was taking the cartridge out and rubbing the terminal with a scratch free cloth. I was fustrated with it so rubbed it quite hard but supprisingly when i put it back in it worked.
Jan 29, 2010 | Epson Printer
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
C3300n toner low
This mesage often appears because you refilled the toner. The chip in the toner is sayingthat it is empty, but I can assure you it is full because there is no sensor in the cartrage that keeps track of this. Use genuine toner next time, as refilled or remanufactured can break your printer over time.
Mar 19, 2009 | OKI C3400n Laser Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Samsung ML-2152W
The problem is that the cartridge you re using was reloaded with toner, but the remanufacturing process did not include replacing the chip. The ML2150 and the 2151N do not read the toner's chip on boot, but the 2152W does. So you either have to get a cartridge that has a new chip or get a new, genuine, Samsung cartridge.
Jun 01, 2008 | Samsung ML-2150 Laser Printer
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
