Question about Epson PictureMate Flash PM 280 InkJet Photo Printer
Picture mate.pm210 wast ink pad counter - Epson PictureMate Flash PM 280 InkJet Photo Printer
  • 3 Answers
E-90 printer error
Posted on Sep 03, 2010
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.ssclg.com/epsone.shtml
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Waste Ink Absorber is almost full message every time I print
you need to change the inks waste pads, and reset the ink waste counter in service mode.
you can just reset the ink waste counter and still use the machine but it will probably start leaking a bit of ink after a while unless you sit it on something to absorb the excess ink.
to reset the ink waste count just do a search on the web and you will find it pretty easy to do.
Apr 01, 2009 | Canon PIXMA iP1600 Printer
Can't print with Epson stylus C67
It means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from http://www.ssclg.com/epsone.shtml and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service
manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 06, 2008 | Epson Stylus C67 Photo Printer
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
Epson PictureMate  Flash PM 280 InkJet Photo Printer Logo
313 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
