Question about Refrigerators
Cutting out then making noise in the motor re-set it by switching off at mains but problem comes back. underworktop model Many thanks
    President:
  • 1,891 Answers
Sounds like a failing compressor . you may want to try a hard start kit like the supco pr # urco410 . this will cover most units and works well .. ( east to hook up ) mm
Posted on Sep 01, 2010
Why won't my carrier furnace come back on?model number 58rav095.It was running and heating,but makes a horrible noise on start up.Is it the motor going out?
If the noise is coming from the fan coil unit then it could be the blower motor. If the bearings are failing it will make noise on start up and run. But after a period of time it will overheat and the overload protection switch will lock it out to keep it from running until it cools down.
Mar 10, 2015 | Carrier Heating & Cooling
MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
Sep 21, 2008 | Minn Kota Maxxum 80 Freshwater Bow Mount...
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
I have a carrier furnace the control board keeps coming up with differ t led coxes ifiI reset it it works a couple times then flashes a new code had four different codes come up so far 21 22 31 34
Feb 05, 2014 | Heating & Cooling
System lockout code keeps flashing and furnace won't start
Jan 21, 2014 | Heating & Cooling
Switch is on-off, the pressureis 0-90psi, and the switch is a close contact position,there is power from the main source to the switch, but no power from the switch going to the motor, what might be the...
Hi, my name is John. Welcome to FixYa. If your switch is set at auto, and your cut in pressure is say 90psi and cut off is say 125psi, and your compressor does not come on due to no current, then the switch is bad. Look on the switch, it will have the information. Thanks for choosing FixYa...John
Nov 26, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I have a Model DX-R24TV suddenly it wont come on green power "on" light flashed and now I hear clicking inside what is it and where can I get parts?
The clicking noise you are hearing can be from the HT power section. The Main power is trying hard to switch on the set but the feedback signal is missing to the SMPS-switch mode power supply- that makes the protection to cut and power. You will need to check onthe EHT, the line output transformer, the EHT driver transistor and the allied ccircuits for any short which is making the +B cut off. check onthe high voltage capacitors, the vert output also for any short. replace the shorted component. The spares must be tried for availability in the nearest spare shop. If it is the EHT you must check and decide with the price of a new one. I hope this helps. Good day
Jul 05, 2010 | Televison & Video
The windsield wipers went out it makes a noise but
It sounds like the wiper linkage has come loose. Need to remove cowling just below windshield to inspect.
Charlie
Aug 22, 2009 | 2000 Nissan Xterra
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
