Question about AudioBahn A4002V 100W x 2 Car Amplifier Car Audio Amplifier
My AudioBahn A4002V gets heat up and stops working. it works back when it cools down. im running 2 900 watt 10 inch audiobahn immortal-series.
  • 631 Answers
SOURCE: Audiobahn A4002T that keeps popping fuses
Does it blow them immediately when inserted, only after the headf unit is turned on or only at high volume?
Posted on Jun 08, 2008
  • 631 Answers
SOURCE: audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 25, 2008
Audioaholic
  • 376 Answers
SOURCE: Audiobahn A2800E Amp
well it depends on your sound preferences, as well as what its going into(vehicle)would need more info to make such a sugestion
Posted on Sep 11, 2009
  • 506 Answers
SOURCE: audiobahn a8002t amplifier in protection mode
Let's measure some voltages. If you have a DMM measure the DC voltage at your amps power supply input. If much less than 10 volts I would suspect you may have possibly damage your power wire. When you have a lot of current flowing through a wire the resistance will change and cause a larger voltage to drop across that wire. Having to low of an input voltage is a trigger mode for some amplifiers to go into protection. Let me know what you find and we can go from there.
Posted on Dec 22, 2009
  • 155 Answers
SOURCE: audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Posted on May 11, 2010
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
How do i get the most watts possible from this amp, with out overheating the amp.
you can run your amp at 1 ohm you would need to to have the right ohm subwoofer wired in parralle to get 1 ohm at amp ...... the put a 12 volt fan in the area to keep the amp cool so it doesnt over heat if you plane to
Audiobahn A2X400HQ 2 Ch Amp
1600w x 1 @ 1ohm - 800w x 1 @ 2ohm
600w x 2 @ 1ohm - 400w x 2 @ 2ohm
2-Channel High Current Amplifier -- Ideal for use with all Audiobahn Rack Mount Products
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | AudioBahn A2X400HQ Car Audio Amplifier
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Sep 25, 2010 | Car Audio & Video
How do you wire up a audiobahn immortal
is it a singel or dual connector. can u conn 2 or 4 speaker wires je
Nov 15, 2009 | AudioBahn Immortal AWIS10P Subwoofer Car...
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
I need the right box for my subwoofer
go to audiobahn.com and you can download your manual for your audiobahn under tech support
Apr 03, 2009 | AudioBahn AW1251 Car Subwoofer
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
Is it enough
Audiobahn subs are not too powerful and they can not handle too much continuous RMS, be careful they will heat up and tear off the voice coils off ur subs. run about 100 - 150 RMS at 75 HZ to each sub and keep the gains at about 3/4 this way you will avoid blowing out your subs. It also depends on the amp? What kind of amp is it?
Let me know if you wish. Otherwise
Oct 21, 2007 | MA Audio HK4000D Car Audio Amplifier
AudioBahn A4002V 100W x 2 Car Amplifier Car Audio Amplifier Logo
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
