Question about Samsung SCX 4521F All-In-One Laser Printer
The paper feed does not start to make a copy until about 10mm of the original has been feed into the copier. Hence the copy does not have the header that the original would have.
  • 360 Answers
Hello check paper sizes.
it is change
Posted on Sep 02, 2010
Re; fr3950EP machine, I moved the paper sideways 10mm, light gone out and machine won't start again, display panel just says check paper feed area
Pls, I have risograph FR3950EP
I need the full drum unit, computer interface card, master and inks of different colours. Kindly help me out. I am in Nigeria.email: engrmoob@yahoo.co.uk
Nov 26, 2011 | Riso RZ220 Duplicator
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
I have a brother copier model dcp 7025 and am experiencing a vertical line on copies where the original is fed through the top feeder tray but the copies are fine when the original is placed directly onto...
Depends which way is vertical but I think the feed rollers on the upper tray are slipping perhaps dirty. (The paper momentarily stops feeding past the scan sensor)
Jul 14, 2008 | Brother Office Equipment & Supplies
Copying problem
check paper through paper cassette, then through bypass,if fault occurs on both, it is possible the registration roller area is possibly faulty.
There are other reasons for this relating to image formation, but please start with paper feed.
Jan 29, 2008 | Sharp AR-207 Copier
Paper feed
Make sure what you are trying to print fits on 1 page. Check your margins, headers, etc.
Dec 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Samsung SCX 4521F All-In-One Laser Printer Logo
69 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
