System message at start: no boot device available no bootable devices
What type of software do you have? If it is XP then the bios is not finding the hard drive. You will need the original XP CD.
Posted on Sep 01, 2010
3 Suggested Answers
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
  • 73 Answers
SOURCE: Laptop won't boot.
If it used to start up OK, then the hard drive is probably broken and needs to be replaced.
If you're adding a new hard drive, it may need to be partitioned and formatted. Insert your Windows CD, and start up off that, and run the Windows setup. It will format and partition the drive for you.
Posted on Feb 08, 2009
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
My pc wont boot. All i get is " reboot and select proper boot device or insert boot media in selected boot device and press a key"
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
Jan 20, 2014 | Computers & Internet
No bootable device PXE-M0F
You need to disable booting from the device in the Bios. It will be under the Boot options menu. Uncheck it from the list of devices to boot from.
Aug 22, 2012 | Acer Aspire 9300-5349 Notebook
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
Reboot and select proper boot device. what does it mean?
Boot device per see means that it is the device where you want your computer to start it may in the form of Optical drive (CD, DVD), Harddrive, USB drive (thumb drive), Floppy drive (for old computers). When get this error it also means that there are devices you have that are bootable it may be in a form of an Operating System Disk or just a simple bootable floppy drive. But the usual bootable device once you had the operating system installed already will be the Harddrive.
Apr 22, 2011 | Microsoft Windows XP Professional
The problem is my emachine laptop does not want to start up it is asking me a boot decives wch l dont have, the model for my emachines is E525, where can l get the boot device?
It is asking you for a bootable drive or device.
Your windows OS is your main bootable device, if it is not booting, you must have a error in your windows installation.
Other bootable devices can be your Windows CD, or a USB drive with some bootable media on it.
Try tapping F8 when you turn your PC on, it will give you the option to boot into safe mode, or may also give you repair / restore options.
Try booting into safe mode and do a system restore
Sep 30, 2010 | Computers & Internet
Dell dimension 5100 original partitions have been wiped .. Now need to reinstall xp . I can not. Selected boot device not available. can not do ctrl-f11 anymore of course btw just in case you were thinking...
If you are getting message the message "selected boot device not available" that is because you have do not have a bootable HDD (Hard Disk). Please do the following:
Insert the Windows XP Operating system Disk.
Restart the computer and start Tapping the F12 key, It will give you the boot options.
Select to boot from CD/DVD-Rom
When prompted press any key to boot from CD-Rom
Once the computer is booted from CD, follow the instructions to install the Operating system.
Note: You can also go to BIOS (by pressing F2 or Delete) and change the boot device to CD-ROM
Once you finish installing the Windows Operating system. You can go ahead with installation of your Linux Operating system. After you finish Installing Linux you will get the option in GRUB to select the Operating systems.
If you have already installed Linux and want to install the Windows, Follow the same procedure but it will directly boot Windows after you finish Installing Windows. You will have to write the GRUB again for your Linux system.
Please get back for any further assistance.
If you find this solution helpful, Please do not forget to rate it.
Thank you for choosing Fixya.
Nov 14, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Bootable files
When a computer is powered on, the BIOS ("basic input output system") has only a few commands available to it, and the main one is to search for a "boot device" - a storage device which contains "bootable files". The first device it finds with "boot records" is used to load the operating system.
Usually this is the C drive, but could also be a floppy, USB flash memory, or CD.
In order to get the boot records onto a device, a special option must be used when the device is formatted. This boots the boot records in a place where the BIOS knows to look for them.
So, a bootable file (or "bootable device") is a storage device which has been set up with these boot records.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Apr 27, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
