Question about Microsoft Internet Explorer 7
How to fix my explorer.exe - Microsoft Internet Explorer 7
    President:
  • 2,291 Answers
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. and after this run registry cleaner reg in out
Posted on Sep 22, 2010
I have a black screen that says reboot how do i do that
When you log on, push Ctrl-Shift-Esc. This will open up the Windows Task Manager. Now click on the button that says new task. Type in "explorer.exe" (w/o quotes), and then click OK. This should fix it temporarily.
For a permanent fix, go to the start menu and then type in regedit. Navigate to:
=> HKEY_LOCAL_MACHINE
=> SOFTWARE
=> Microsoft
=> Windows NT
=> Current Version
=> Winlogon
Once Winlogon is selected, make sure that the Shell key is set to explorer.exe. If it says something else double click and change it to explorer.exe
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 21, 2012 | ASUS Computers & Internet
Tip
Renaming The Start Button:
To rename the start button, you will need a hex editor.
My preference is UltraEdit
Copy the \windows\explore.exe file to a new name (e.g. explorer_1.exe)
With the hex editor, open that file and go to offset 412b6
You will see the word start with blanks between each letter
Edit it be any 5 characters or less
Save the file
Boot to DOS
Copy the existing c:\windows\explorer.exe to explorer.org
Copy explorer_1.exe to explorer.exe
You will also need to replace the explorer.exe in the c:\windows\system32\dllcache file as well with the new one.
Note: If the partition is NTFS and you can't access the files from DOS:
Start Regedit
Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon.
Change the value of Shell from Explorer.exe to explorer_1.exe
on Mar 07, 2008 | Microsoft Windows Vista Ultimate Edition
My pc shows end program-explorer.exe
First thing you need to scan your hard drive for a possible virus infection.
If the anti-virus cannot find and fix the problem, the explorer.exe file is damaged/corrupted and you need to have it replaced by reinstalling Windows.
Regards,
Katharsys
Mar 30, 2011 | Computers & Internet
I reduced the volume of my laptop.the next day i turned on my laptop and i could not find the icon volume in my system tray.it desappear and the volume box is gray .how can activated.thanks
Hi micochereami,
You can fix this issue by restarting the "explorer.exe" services. To restart the explorer.exe service, please perform the steps given below.
  1. Right click on the Taskbar and click the "Task Manager" to open it. (You can also press "Alt+Ctrl+Del" or "Ctrl+Shift+Esc" to open the Task Manager.)
  2. In the Task Manager window, please click the "Process" tab.
  3. In the Process tab, locate the "explorer.exe" process.
  4. Once you have located the "explorer.exe" process, please right click and select the "End Process" option.
  5. Then, please click the "File" option in the Task Manager window and select the "New task (Run..)" option.
  6. Then, in the Create New Task window, please type "explorer.exe" and press the Enter Key.
  7. This should fix the issue.
Good Luck!
Please post if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 08, 2010 | Sony VAIO VGN-CS215J/W Notebook
The Screen stays blue I have no icons start menu I cant access the control panel there is an error message that says explorer.exe application error 0xc0000005 I cant restore the system but if I access Task...
just get into safe mode by pressing f8 , then click the command prompt from the start menu or if you dont get the start menu press ctrl+alt+del key to get the task manager and go to file and click new task run the command prompt from there. Then in the command prompt type sfc scannow it will ask for the win xp cd for xp and for vista or 7 it automatically scans and fixes the system file errors.Let me know if still the errors are there.
Jul 03, 2010 | Computers & Internet
Explorer.exe always restarting
Try to restore explorer.exe from orignal windows installation disk, if this does not solve the problem scan your PC with good antivirus software linke, quickheal or norton
May 29, 2010 | Computers & Internet
After log in to the my laptop after one are two minutes curser is not working and the system is not workig how to fix this problem
press ctlr+alt+delete
it will bring up the task manager.. go to process tab | kill the explorer.exe then go to file | new | explorer.exe (type explorer.exe in the box )
then do a full system scan for virus or trojans with a good antivirus like avast or antivir
Dec 19, 2009 | HP Compaq nc6120 Notebook PC
How can i fix m3plugin .dll error
Do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
In Regedit go to;
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
and delete any value except "Default".
then go to;
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
and delete value except default and anti virus.
Best of luck.
Hasan
Dec 05, 2009 | Intel Motherboard
Safe mode not working either
I believe your problem lies in the process explorer.exe
To fix this I would press Ctrl + Shift + Esc and the task manager will come up.
Once it does click the Processes tab and look for explorer.exe and right click it and choose End Task.
Then you need to click File > New Task
and type in:
explorer.exe
If it dont work let me know and I will look into a different method.
Dec 18, 2008 | Toshiba Satellite A105 Notebook
Explorer.exe
Insert Windows XP cd on drive, and use upgrade option.
Dec 13, 2007 | Computers & Internet
Microsoft Internet Explorer 7 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
