Question about Siemens Freezers
Hi I have an upright Siemens freezer (model E000786) which is 9 years old. It still works well but I have found for the last couple of years that it needs defrosting more frequently due to the ice building up. I'm in the process of defrosting just now and a friend had suggested that I should let it defrost for a longer time to allow the internal pipes to defrost and 'drain away'. Is this worth doing and if so, how long should I leave it after there is no visible ice. Also how would I 'drain it' Look forward to hearing from you (soon please?) Thanks Linda
  • 4,793 Answers
A full defrost will take,depending on room temperature,about 12 hours,DO NOT USE HOT WATER/SHARP OBLECTS.
you can use car deicer but it will leave a residue/smell that you can remove by wiping out with clorine bleach.make sure any drain holes are syringed out with clorine and wipe out any drip tray to stop smells.by drain away he probably means"dries naturally"
do make sure all food is wrapped/covered (clingfilm) to cut down on frost/condensation inside the unit.after a full defrost fill with your usual foodstuff and fill any space left with newspaper filled poly bags.(less airspace=more efficient)
Posted on Sep 01, 2010
Freezer is 11 years old. Alarm has gone on and freezer is not very cold. Has it died or can it be fixed?
Hi there. I really think it could be a thermostat or a small fault. But jump on Google to look for faults with that model. Let me know how you go
Jun 02, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | Whirlpool Freezers
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
May 29, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not freezing
Is it running? You might need to put your ear up to machine, to hear it, They run very quitely.
If not running, could be a bad cold control (thermostat), or defective relay and overload mounted on the compressor body.
If the compressor is running but no cooling, then you're in serious trouble unless,
The unit is 5 years old or newer. In that case you have factory warranty on what is called the sealed system. Contact the dealer in that case for service. Service should be free.
Oct 30, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Dec 19, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezers Logo
229 people viewed this question
Top Siemens Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Siemens Freezer Expert? Answer questions, earn points and help others
