My HCL computer: Monitor is working alright. when connected to CPU there is only yellow light and the monitor is not opening. there is no signal in the monitor.How to make the computer functioning.
    Sergeant:
    Champion:
  • 389 Answers
Try to check that the memory is in all the way,pull the memory moduals out and reseat them,if your useing a video card (and not an onboard video)reseat it also.
Posted on Sep 02, 2010
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
I used CRT monitor now iconect hcl 710 Lsa model lcd monitor no signal disply. an other cpu accept his monitor working good what problem ? My cpu core 2 duo intel prosser 2 gb ram 2ghz
Possibly, the CRT monitor was set to a frequency which is too high for the LCD monitor.
Try booting in Safe Mode (press F8 at boot), then set the video for a lower resolution.
Reboot with the new, lower, resolution.
In Control Panel choose Hardware, then Scan for New Hardware and get the LCD monitor recognized.
Then, from the Desktop properties, you will be able to see all resolutions supported by the monitor.
Nov 03, 2009 | Honeywell Computers & Internet
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
URGENT Big project due...Monitor won't stay on...light goes yellow after initial message c below
check the cable which connects from the monitor to cpu is connected properly... if it s not connected properly this problem occurs.. just reconnect it ... ur problem will be solved...
Dec 03, 2007 | Sony SDM-HS73P 17" LCD Monitor
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
